Headers, F250 HD 351W
My son has a 96 F250 with the 351W engine. We have been looking at headers for this truck. All the ones we can find have the fittings for the O2 sensor and the EGR tube. What they don't have is fittings for the air injection located at the back of the engine on the exhaust manifolds. I was thinking we could fab up tubing so this will still work. Either dump it into the collector or the closest header tube. Has anyone put headers on this style of truck and how did you address the air injection? Thanks
If you don't have emissions test, you can do away with all of that stuff. My 89 doesn't have any of that stuff anymore and runs fine.
Anyway, I'm fairly sure that you can just let those tubes pump and not plug them in. I don't think they really matter. If there is a better solution somebody will know I'm sure.
on
If you're doing away with the stock cat then the whole air injection system serves no purpose so you may as well remove it. The TAB and TAD solenoids must remain electrically connected with vacuum sources plugged, and the air pump itself can remain as an idler so you don't need a shorter belt.
*edit* Found these: Flowtech Part #: 91668-1FLT Shorty Smog Headers. Sounds like this is the ticket.
Ray
http://www.summitracing.com/parts/jb...-250/year/1996
These claim to work with air injection. But they are ridiculously expensive. like more than $800
coplin
43
07-09-2005 02:35 PM
