Adjustable camber bushings
Old 03-30-2013, 07:07 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
How hard are these to install? Is there a how to somewhere? I put in my leveling kit thinking I could get it somewhat close and its way off so I need to get these now. My mistake for not planning ahead.
Old 03-30-2013, 07:11 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Also, where is the best place to get what I need?
Old 03-31-2013, 08:47 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Pretty easy install. Remove upper ball joint nut, remove camber sleeve that's currently in there, install adjustable sleeve. Sometimes the sleeves are a pita to get out. It'd probably help to spray penetrating fluid on them for a couple days before you're doing the job.
There should be a chart with your new camber sleeves that outlines what number/letter to set them at to get zero degrees. Install them at zero, check the camber angle with an angle finder, then set the bushings where you need them. Use plenty of anti-seize when you install them.
I got mine at Rock Auto.
Old 03-31-2013, 09:48 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
There were several different ones on rock auto. Which ones should I get?
Old 03-31-2013, 10:25 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
I just need the part number for which one to order on my rwd truck. I'm not concerned with the alignment being perfect, just close enough that the wheels aren't tilted. I'll get it aligned right when I get new tires.
Old 03-31-2013, 11:33 AM
Bob Gervais
What year, model, 4wd or 2wd?
Old 03-31-2013, 11:37 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
94 f150 rwd
Old 03-31-2013, 11:44 AM
Bob Gervais
Moog K80109 are the ones you want.
Old 03-31-2013, 12:24 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Does it come with both of them or do I need to order 2?
Old 03-31-2013, 03:14 PM
Bob Gervais
Order two of them.
Old 03-31-2013, 05:44 PM
bashby's Avatar
bashby
bashby is offline
You are wasting time and $ doing this. Just take it to a alignment shop that can do it. Just lifting it some will throw the camber out but the toe should stay close. Change the ca.ber bushings and you toe goes way out... That will eat tires.
Old 03-31-2013, 07:02 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I have to adjust my camber before I do anything but then I'll take it in to get the alignment done. I don't think setting it up to be straight is ever a waste of money.
Old 04-01-2013, 06:23 AM
bashby's Avatar
bashby
bashby is offline
What about the caster? Everyone seems to think you put the adjustable bushings in then turn them to get the camber right... doesnt work that way. I have done hundreds of alignments with camber bushings in these trucks. You need to get your caster and camber readings, then remove the old bushings, see what offset they are, calculate which bushing to put in or how to orient the adjustable one, then hook the machine back up to verify caster and camber then set the toe. I woould be pissed if someone put those adjustable ones in then brought it to me. they are nearly impossible to get out without destroying them. I prefer the fixed bushing of the correct offset. They cost a lot less also.
Old 04-01-2013, 07:12 AM
Bob Gervais
If alignment shops had bushings in stock, or readily available at parts stores, I agree with fixed bushings 100%. However, at least in my neck of the woods, it's tough to find an alignment shop that's willing to set more than toe on these trucks, let alone have bushings readily available to set camber.
Proper procedure, per Ford, is to remove factory bushings, install zero degree bushings, then calculate what you need. Which is why, when I did mine, I set the adjustable bushing to zero, calculated via the chart included with the adjustable bushings, set the bushings, and installed them. Toe was roughly set, by me, then dialed in at the alignment shop. Took them all of a half hour to fine tune toe, and they actually thanked me for saving them the trouble of messing with the camber.
No matter how it's done, changing camber is going to affect toe, and changing toe (if it's way out) will affect camber.
To the OP, perhaps it's worth a call to your local alignment shop to see what they can do for you, and what their recommendations are about parts.
Old 04-01-2013, 07:36 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
That may be a good idea. Just trying not to spend too much to get it straight.
sandymane
10-06-2017 07:20 PM
v8xploder
1978 - 1996 Big Bronco
05-25-2011 06:27 PM
69mustang
1983 - 2012 Ranger & B-Series
04-12-2010 10:25 AM
el_n
02-04-2005 12:34 PM
carriljc
10-27-2003 03:17 AM
Quick Reply: Adjustable camber bushings
