Power window adjustment
Old 03-30-2013, 11:31 AM
wanness's Avatar
wanness
wanness is offline
All of a sudden my drivers window will not go up with out some external help. Is there an adjustment to take care of this? Thanks, Bill
p.s. 1995 F-350 dually, crew cab.
Old 03-30-2013, 12:30 PM
Boyd'z Toy's Avatar
Boyd'z Toy
Boyd'z Toy is offline
Does the motor bog down, or does the window get cockeyed?
Old 03-30-2013, 01:22 PM
wanness's Avatar
wanness
wanness is offline
Window adjustment
Putting the window down, absolutely no problem. Putting the window up, it will "bounce", if that makes any sense. It will come part way up and stop. When the window is all the way down, I have to take a pair of pliers, put a slight bit of up pressure with the pliers and the window goes right up. When I am putting a slight bit of "up" pressure with the pliers and push the "up" switch, no problem. any help would be greatly appreciated. Thanks, Bill p.s. I don't notice any cocking when the window is coming up.
Old 03-30-2013, 02:52 PM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
it probably just gummed up in there somewhere
Old 03-30-2013, 03:35 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Sounds like a Weak window motor
Old 03-30-2013, 03:36 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
The plastic spacers in the lift motor gear assembly are known to wear then cause this issue. Some info in this thread: https://www.ford-trucks.com/forums/9...or-repair.html
Old 03-30-2013, 03:42 PM
wag53's Avatar
wag53
wag53 is offline
The clutch might be going in the pwr widow motor. You have to take the motor out and get a gear kit from Auto Zone . The clutch is 3 small plastic ***** in the gears. The number is WL33000 by siemens.
Jeff heine
12-18-2016 04:42 PM
f-150 on 22's
2004 - 2008 F150
09-04-2007 09:11 AM
wesmansr
Electrical Systems/Wiring
01-25-2004 10:36 PM
markmacd
1997 - 2003 F150
12-31-2003 09:32 PM
Cameo
1978 - 1996 Big Bronco
05-27-2003 11:42 PM
Quick Reply: Power window adjustment
