Pats problem?
The EE display flashing says to replace the insturment panel.
Your at the the end of this situation , now.
You just saw the value and reason why there is a dash diagnostics procedure otherwise you would never know except change the dash cluster on a guess.
Only possability left is componant solder connnections on the circuit board might be recovered, if that is the problem, using a low wattage iron and some solder, inspecting with a magnifying glass, the connection points.
Good luck.
Good luck.
wmcneil
2015 + Expedition & Navigator
01-07-2017 06:26 AM
