F100 steering gear parts for rebuild 1958 *NumbersDummy*
Old 03-24-2013, 07:53 PM
chadtexas's Avatar
chadtexas
chadtexas is offline
I will be rebuilding my steering gear on my F100. I know NumbersDummy had listed them all out for us a few times on a few posts. I just spent the last hour searching through the posts and haven't been able to find the one where the industry part #'s where listed. I will be purchasing most of the parts from a N*pa parts store. If anyone has the parts numbers could you chime in? (or perhaps the numbers man?) When I do my rebuild I am going to make it a diy pictoral and post it. Hopefully there is a way it can be stickied.
Thanks,
Chad
Old 03-24-2013, 10:11 PM
GPinNC's Avatar
GPinNC
GPinNC is offline
I'll be watching this thread closely because this is a future project for me too.
Old 03-25-2013, 11:59 AM
chadtexas's Avatar
chadtexas
"NAPA sells the parts necessary to tighten up the gearbox.
I rather doubt the parts will cost much more than 75 bucks.
You need two sector shaft bushings: B7C-3576-A
new sector shaft seal: C7OZ-3591-A (replaces B6A-3591-A)
and housing gasket: 7RC-3581
two steering shaft bearings: 68-3571-A (Industry # 5BC)
and races (one each): B-3552 (Industry #6) & 8A-3553 (Industry #6CE)
That should do it. NAPA can cross these Ford part numbers over to the brands they sell. The Industry #'s are what autoparts stores go by for bearings, races, etc.
These same parts are the only parts replaced in rebuilt gearboxes sold by autoparts stores.
While your truck is a 1960 F100, the steering shaft bearings are the same from 1936 thru 1960, one steering shaft race was used 1932 thru 1960, the other race and the housing gasket are the same from 1948 thru 1960, the seal fits most 'everything from 1948 thru 1972, the sector shaft bushings from 1957 to 1960."
This is what I finally found this morning searching the forums. I am having a hard time cross referencing the parts over to N*pa parts numbers. I can't seem to find the interchange anywhere.
Old 03-27-2013, 06:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
^ Hmmm, info/part numbers/applications taken directly from one of my posts.
Would'ja like me to list sources for these Ford parts? I'll betcha most will be located in TX and OH
Old 03-27-2013, 12:49 PM
chadtexas's Avatar
chadtexas
Yep... copy and paste from your post. I searched for hours to find it. It would be worthy of a sticky in the tech forum! If you have availability for vendors would be appre ciated! Thank you
Old 03-28-2013, 09:40 AM
NumberDummy
1) B-3552 .. Steering Shaft & Worm Bearing Cup-Upper.
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
PARTS INTERNATIONAL in Farmers Branch TX has 6 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
ANTIQUE AUTO SUPPLY in Arlington TX has 12 = 817-275-2381.
1) 8A-3553 .. Steering Shaft & Worm Bearing Cup-Lower.
PARTS INTERNATIONAL has 3.
ANTIQUE AUTO has 4.
NOS PARTS LTD has 5.
GREEN SALES has 6.
2) 68-3571-A .. (replaced 68-3571) Steering Shaft & Worm Bearing.
B. F. WHITE MOTOR CO. in Stanton TX has 2 = 432-756-3321.
WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293.
ANTIQUE AUTO has 9 68-3571
2) B7C-3576-A .. Sector Shaft Bearing.
PARTS INTERNATIONAL has 23.
GREEN SALES has 153.
1) 7RC-3581 .. Housing Gasket.
PARTS INTERNATIONAL has 11.
GREEN SALES has 144.
1) C7OZ-3591-A .. Sector Shaft Seal.
PARTS INTERNATIONAL has 50.
GREEN SALES has 133.
Old 03-28-2013, 11:48 AM
chadtexas's Avatar
chadtexas
Thank you Bill!
Old 04-03-2013, 12:12 PM
56 ford custom's Avatar
56 ford custom
56 ford custom is offline
box
Before I tore down my 60 I could turn the wheel about a quarter of the way and then it would turn the wheels. I think it needs a rebuild as well. I'll be watching this. I have never rebuilt a steering box before so don't know what to look for.
Old 04-03-2013, 07:19 PM
spurredon's Avatar
spurredon
spurredon is offline
They are not rocket science, just pay attention as you tear it down and have a shop manual.
Old 04-03-2013, 07:32 PM
56 ford custom
I have been looking for an original master shop manual that covers 57-60 that I can't find. Also.a kit for the steering box.
Old 04-03-2013, 07:43 PM
chadtexas's Avatar
chadtexas
I just bought a shop manual on CD and I'm not sure if it has anything on the steering box. Hopefully I find something. I think there are kits around through the vendors. I ended up piecing my "kit" together with just the soft parts , gaskets and the bearings. When I open it up I will know if I need to replace the sector shaft etc. I will try to take pics of the rebuild. It truly is less involved than motor assembly (which i've done on many a motor) so It should be a fun process to learn. Hopefully I don't need a new shaft etc. It gets pricey.
I talked to someone at a junkyard recently that has older cars, and they mentioned one thing to check before the rebuild is the condition of the cab mounts, and sheetmetal of the cab supports. If there is any cab "sag" or flex under cornering etc. he mentioned it would put a bind on the column and accelerate the wear on the box/bearings and bushings. I hadn't thought about that but it makes complete sense.
jpb222
05-27-2023 09:28 PM
dadwood
39
07-14-2011 01:35 PM
Moose2
03-29-2011 07:45 AM
salf100
02-19-2011 02:51 PM
billjhs
05-14-2003 04:56 PM
Quick Reply: F100 steering gear parts for rebuild 1958 *NumbersDummy*
