Massachusetts Chapter Join Chapter, Leader: donjamer
Door Mirrors
Old 03-19-2013, 12:09 PM
white-horse's Avatar
white-horse
white-horse is offline
Door Mirrors
As you can see in my picture, I have the large mirrors that are mainly used for trailering and such. I am thinking of swaping to the standard mirror. I already measured and the bolts on each mount line up perfect. It appears I can easily swap them out. Do all agree? Or will I have problems? Other than being left with the two bolt holes on the lower part of the door? (which I will fill in). Thanks.
Old 03-20-2013, 06:45 PM
donjamer's Avatar
donjamer
donjamer is offline
I would say stay with the ones you have.. Better visibility even if you are not towing..
If you ever do tow anything you will be glad you have them..
Old 04-12-2013, 01:59 PM
white-horse
I made the conversion. I like the new mirrors much better. They installed perfect. I was nervous at first, as I had to take the door panel off in hopes to find that center bolt attachment for the new mirror...it was there! No drilling. As for the two holes in each door, I plugged with a stainless round top bolt, painted white. You can tell of course, but it doesn't look hideous. i'm happy...
Old 04-12-2013, 02:01 PM
donjamer's Avatar
donjamer
donjamer is offline
That sounds like a good thing using the bolt..
Now you have the option of going back if you choose...
Old 04-12-2013, 02:09 PM
white-horse
Yeah, that's what I thought. Some said I should weld it closed, sand and paint, others said use bondo (yeah right). The bolt worked great, won't rust, plus I coated the threads and washer on the inside with grease. Done.
Old 04-12-2013, 02:12 PM
donjamer's Avatar
donjamer
donjamer is offline
That seems to be the best option if you ask me..
Not much effort and should last a long time..
ford4dogerfan
04-07-2015 04:58 PM
kupiec20
23
09-24-2013 06:11 AM
str8sixman
06-22-2012 09:00 PM
andrewrj
1978 - 1996 Big Bronco
05-07-2004 01:25 PM
agm104
Paint & Bodywork
10-12-2002 08:23 PM
Quick Reply: Door Mirrors
