Massachusetts Chapter Join Chapter, Leader: donjamer
Air Filter/Intake Unit
Old 03-19-2013, 11:56 AM
white-horse's Avatar
white-horse
white-horse is offline
On my 97 f-350 7.3L, is the factory stock air intake system fine for general use? Or, should I invest in a high performance aftermarket? Also, I missed out on the recall they had some years back on the filter houseing cover, something with the screw down bolts or something, anyway, that recall has ended,,,where can I get the "recall" parts now??? Thanks.
Old 03-20-2013, 06:43 PM
donjamer's Avatar
donjamer
donjamer is offline
The factory stock intake is better than the aftermarket ones.. There are many threads on the subject.. It doesn't have any benefits to replace it..
As far as the recall, did you check out the dealer to see if you are not eligible??
They should be able to get the parts unless they are discontinued..
Also check out the TSB and Recalls for your vehicle at the top menu under Tech Tools
Old 03-21-2013, 09:19 AM
white-horse
Ok, thanks! I'll keep the factory air filter intake unit, and I'll look at that recall. That recall has expired, can I still get the parts? I guess I have to check with the dealer.
bebeard
12-20-2011 05:48 PM
jdamato1
02-21-2010 03:18 PM
europrojektzbmw
05-23-2007 11:27 PM
Billabong
09-14-2005 12:29 PM
Quick Reply: Air Filter/Intake Unit
