Fixing Rusted Bed Rails
Old 03-15-2013, 01:04 PM
fordtruck661's Avatar
fordtruck661
fordtruck661 is offline
Hi Guys
My trucks bed support rails are rusted out where one side has dropped about 2". But the rest of the bed looks ok little to no rust just the rails. Im thinking of going and buying some 2x2 steel tubing and cutting the old supports off and putting this as a replacement. Has anyone done this? or have any better ideas? I think it will be a lot cheaper than buying a non rusted bed.
Thanks
Old 03-15-2013, 02:36 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Originally Posted by fordtruck661
Hi Guys
Thanks
One of the guys had some bent up and replaced them himself. I need to do the same to my truck. He had removed the bed to do them. when finished he had coated it with chassis saver paint as well. I am going to go that route as well when I do mine..
Old 03-15-2013, 02:37 PM
hammer65's Avatar
hammer65
hammer65 is offline
Some one posted with Pix, about how he replace his. Maybe do a search
Old 03-15-2013, 04:13 PM
megawatt00's Avatar
megawatt00
Here is the thread. it is a few years old and seems that the pics have been deleted on Photobucket. I can call Phil to see if he still has the pics somewhere.
https://www.ford-trucks.com/forums/1...-very-bad.html
Old 03-15-2013, 06:31 PM
BNSONS's Avatar
BNSONS
BNSONS is offline
Here you go, let us know how it works out.
Dave
https://www.ford-trucks.com/forums/1...storation.html
Old 03-15-2013, 06:49 PM
fordtruck661
If you could that would be great I would like to see the pieces of metal that he had bent up and the finished project.
Old 03-16-2013, 03:08 PM
fordtruck661
I found these on ebay Ford Super Duty Bed Floor Support Crossmembers Rails | eBay
Seems crazy to pay almost $500 for these things.
Old 03-18-2013, 08:36 PM
anotherfordguy's Avatar
anotherfordguy
anotherfordguy is offline
I am just going to build a new bed when I can find the time. Between the floor, tailgate, and wheelwells I figure its not worth the effort to save it. Plus it would be alot more fun to build one out of tube.
First I have to fix all the cab rot.
Old 03-18-2013, 09:11 PM
binuya's Avatar
binuya
binuya is offline
No kidding! Surely someone could fab something up cheaper than that. Besides, if those need to be replaced, the bed will likely have some cancer on it that needs to be dealt with as well. Those things are not worth what they're asking.
Old 04-18-2013, 11:44 AM
fordtruck661
Well Im starting to get everything I will need together so far I have por15 and went and got the metal yesterday cost me about $100 for it cut to size.
Old 06-08-2013, 08:43 PM
fordtruck661
Well I got the project started last Wednesday so here is the progress.
This is what it looked like when I just took it off
Old 06-08-2013, 08:47 PM
brwolfjr's Avatar
brwolfjr
brwolfjr is offline
Are you going to coat the frame rails?
It also look like you need some exhaust work.
Old 06-08-2013, 08:49 PM
fordtruck661
This is after lots of wire brushing
And after using POR15 MARINE-CLEAN and PREP & READY
Old 06-08-2013, 08:58 PM
fordtruck661
This is after 2 coats of POR15
Tomorrow I plan on sanding and painting the bed..... More Pictures to come.
Old 06-08-2013, 09:04 PM
fordtruck661
I think the above pictures should answer all your questions.
Quick Reply: Fixing Rusted Bed Rails
