Brake Pedal Issues
Old 03-12-2013, 06:46 PM
JRB65's Avatar
JRB65
JRB65 is offline
Brake Pedal Issues
Is there supposed to be some sort of return spring on the brake pedal? I cant seem to get the brake lights to stop sticking on and if the pedal returned to the forward stop it would work. Im just wondering if there is supposed to be a spring or is there some sort of adjustment somewhere Im not seeing.
JRB65
Old 03-12-2013, 08:04 PM
mark a.'s Avatar
mark a.
mark a. is online now
No spring. What year and model are you trying to fix ?
Old 03-12-2013, 10:46 PM
JRB65's Avatar
JRB65
JRB65 is offline
74 F100 Shortbed Styleside Explorer. So is the Master Cylinder supposed to push the pedal all the way back. There is probably about an inch of play in the pedal.
JRB65
Old 03-13-2013, 07:46 AM
Supercab's Avatar
Supercab
Supercab is offline
Are you aboulutely sure that no one has messed with the pedal-as in swapping one from anouther year/model of truck?
If so, its most likely just your brakelight switch itself or the fastener/clip
A new clip "should" come with a new switch, thats what was wrong with mine....cheap enough fix.
Did a quick search:http://www.autopartswarehouse.com/de...EPM506602.html
Old 03-13-2013, 10:52 AM
JRB65's Avatar
JRB65
JRB65 is offline
Did a quick search:1967 Ford F-100 Pickup Brake Light Switch Replacement, OE replacement
Thanks for the info. I actually have a 74 F100 and the switch is kind of a plunger looking switch. I put one in about 2 months ago and being its made in China the spring tention on the switch failed. So less than a week ago I put another one in and now it seems to be sticking on. If I put my foot under the pedal and pull it (the brake pedal) towards me the lights go out. I thought it might be the adjustment of the switch but Ive spent some time trying to get it adjusted right but it still seems to be giving me problems no matter how I adjust the switch. Im about to go to the Ford dealer and see what they give me for a switch and see if it might just be the lack of quality in the switchs im getting from the Auto parts store. Would it be possible for someone to take a couple of pictures of their brake switch so I can make sure im not missing something on mine? Thanks for any help.
JRB65
Old 03-13-2013, 11:21 AM
wilcam47's Avatar
wilcam47
wilcam47 is offline
I think theres a return spring under there it should pull the pedal back, or you could have other things wearing such as the master cylinder/power booster
Old 03-13-2013, 11:26 AM
JRB65's Avatar
JRB65
JRB65 is offline
wilcam47,
Dont know if it makes any difference but my truck has manual brakes. No Power assist except for the extra pressure I put on the brakes with my foot... It has Disc in front and drum in back.
JRB65
Old 03-13-2013, 11:55 AM
wilcam47's Avatar
wilcam47
wilcam47 is offline
Originally Posted by JRB65
wilcam47,
JRB65
could be your brake master cylinder
Old 03-13-2013, 12:30 PM
turbohunter's Avatar
turbohunter
turbohunter is offline
JRB65
Mine is the same. The switch in mine is adjusted almost all the way out.
JRB65
The way the switch works is, when the pedal is at rest the plunger is pushed in by the stop which separates a set of contacts inside by pushing a center piece of plastic in between the contacts.. The contacts are separated so the circuit is open. As you push on the brake pedal the plunger extends sliding out the center piece and allows the contacts to touch, completing the circuit, brake lights go on.
There are better switches available. You just have to get your parts store to find them. Mine did.
No return spring, it's all master cylinder pressure.
Old 03-13-2013, 03:06 PM
JRB65's Avatar
JRB65
JRB65 is offline
Thanks for the info... Im kind of thinking about changing the master cylinder just due to the fact that it looks like its been in there forever. I know my brakes are manual and I have driven other vehicles with manual brakes but you really have to get on these to stop. It may just be a Ford thing but Brakes are one of those things I dont like to take a chance with... I cant remember what website I was on but I saw a higher dollar brake switch and I need to find it again. Thanks again.
JRB65
Old 03-13-2013, 03:40 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is not the same type of switch the OP's truck has. The switch used in 1967 is 1967 only!
D2TZ-13480-B (replaced C8TZ-13480-B) .. Stop Light Switch-Round threaded plunger type (Motorcraft SW-691-A) / Obsolete ~ Available from autoparts stores.
Brake pedal has a bracket made as part of it, has a round hole in it. C8TZ-13A629-A adapter fits into the hole, then the switch threads into the adapter.
Applications: 1968/74 F100/350 / 1975/76 F150/350 300/360/390 / 1975/77 F100 / 1975/77 F150/350 460 without Speed Control / 1978 F100/350 & Bronco before serial number CC0,001.
wilcam47: There is no brake pedal return spring, N-O-N-E = NONE!
Old 03-14-2013, 10:46 AM
JRB65's Avatar
JRB65
JRB65 is offline
Number Dummy,
Thanks for the info.. I seem to be missing the Adapter that you discribed above in mine. Im wondering if that could cause the problems im having. Anyways thanks for the info... Also is that a Ford Part Number for that Adapter you mentioned above? I think I am going to go to my local Ford Dealer and ask if they might still have one in stock...
JRB65
Old 03-14-2013, 11:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
JRB65, I'm rebuilding my dash right now and I'll post some pictures in a little while of the pedal, adapter and switch and how to "get around" the adapter if you don't have it.
Old 03-14-2013, 11:25 AM
JRB65's Avatar
JRB65
JRB65 is offline
Thanks mikeo0o0o0,
Right now I have two nuts on the barrel plunger switch and they actually came with the switch i bought just a week ago. Anyhow I really appreciate you posting some pictures.
JRB65
Old 03-14-2013, 11:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks mikeo0o0o0,
JRB65
That's how you get around the adapter .
Here are the pictures of the stock set-up, the adapter and the switch with the tinnerman nuts.
Quick Reply: Brake Pedal Issues
