Radius Arms
D6TZ-3A360-A (replaced C6TZ-3A360-A & B) .. Radius Arm ~ Right/Left is the same / Obsolete
Applications: 1966/76 F100 4WD / 1966/77 Bronco / 1975/77 F150 4WD
No Ford Dealer or obsolete parts vendor has any.
C6TZ-3A360-A =
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
Try broncograveyard.com for a user.
The areas where the bushings ride at the frame mount end of the radius rod were "wallowed" out on my 1978 4WD F150. I laid down a few beads and then ground the welds down smooth. I have had no issues thus far, but I would hate to see the aftermath of a failure, therefore take my advice at your own risk.
1978/79's use different radius arms. Notice that the applications for D6TZ-3A360-A are 1966/77.
No such Ford part number of D6TZ-3A360-C / Look at it again, it's either D4TZ-3A360-C or D8TZ-3A360-C .. as these are the only radius arms used in the 1970's w/a C suffix.
Neither is correct for the OP's truck.
Originally Posted by wdfp
I saw U-haul on ebay has 2 new ones but they must be 2wd as the # is the same except for the last letter which is a C
Probably an error on their part then, I imagine when you list that many parts it would be easy to make a mistake
Ford Arm D6TZ3A360C | eBay
You may need to copy and paste that link but I tried it and it takes you right to it
Originally Posted by YooperUno
So what are u r telling me then 1975/77 F150 4WD r the only ones that will fit my truck?
RVF150
37
03-16-2018 02:49 PM
FordStolz68
03-10-2016 08:42 PM
Bootlegger's Deluxe
09-24-2013 06:12 PM
