A clutch fork pivot ball question
Greetings all, I recently have researched replacing my hydraulic master-slave assembly on my '86 with an earlier manually actuated clutch fork. I have acquired the necessary pedal-hanger-rod-bellcrank-stud from an earlier manual clutch "82" f150. I realize my clutch fork is somewhat different and I will procure a new one but I can't find the info on whether or not my clutch fork pivot ball (in the bell housing) is different from the one I now have.
I AM assuming that my present bell housing will accommodate the manual linkage clutch fork even though the current bell has a small mounting flange for the current slave which can ether be removed if in the way or will be ok as is.
If anyone has any knowledge or even the part numbers of the pivot ***** involved it would be a tremendous help. I can of course research this when it's apart but a little planning seems in order here.
Thanks a bunch for any input..
I'm going to look into that heims fitting option for the pedal assembly I have found..We'll let you know how that all works out.
Again, thanks
I haven't gotten a look inside the bell yet on my hydraulic clutch 86. Will I need a manuual clutch bell you're saying to use the EOTZ-7515-A fork?
It has been a little hard to peice together any info about this not seeing the different bell's up close. for me
Thanks for your input
It's not the fork you should be concerned with...just yet. The clutch equalizer (Z) bar rides on two pivots: Outer, located on the frame rail, inner (engine side) on the bellhousing.
This inner pivot (300 I-6) is a threaded stud, how will you thread it into to a hydraulic clutch bellhousing since there's no place for it?
Hopefully Gary or Chris (ctubutis-moderator of this forum) will scan/post the truck parts catalog pic, so you can see the whole enchilada in an exploded view.
And, if the parts you acquired came from a 1979 or older, they're not going to work, as FoMoCo changed the entire clutch mechanism in 1980.
It's not the fork you should be concerned with...just yet. The equalizer (Z) bar rides on two pivots: Outer, located on the frame rail, inner (engine side) on the bellhousing.
This inner pivot is a threaded stud, how will you thread it into to a hydraulic clutch bellhousing since there's no place for it?
I should say that Chris and Gary both have contributed info on this change on another post https://www.ford-trucks.com/forums/1...-hyd-one.html?
So, at this point I have what I need to do everything except use the older fork. (assuming this older pedal assembly from an 82 will install if need be)
Welcome back, Bill!
Hey guys I have a related question to this.
I'm putting the original SROD back into my truck. I was given the transmission with a bucket of parts, so I'm not sure if it's all there or how it goes back together.
I have the same fork that was shown in the pictures, but have no idea what the spring retainer thing drawn is about. Am I missing something on my fork?
Also, it seems like the piece of metal covering the ball in the fork is what rides on the pivot in my bellhousing, but that doesn't seem right to me. Any advise with maybe a picture would be awesome.
Thanks guys,
Brandon
Thanks guys,
Brandon
MONAVIERONJON
11-05-2012 05:35 PM
phoneman91
12-06-2005 11:50 AM
farmF-150
07-28-2003 12:46 PM
