97' F450 DRW 4X4 chip truck
Old 03-01-2013, 06:35 PM
97F450DRW4x4's Avatar
97F450DRW4x4
97F450DRW4x4 is offline
Hi all, first post!
excited to be able to learn stuff for this 97' F450 im getting in a week or so...
Its got 100K miles with 460, 5 speed stick and 4wheel drive.
Its an X-Davey truck, so word has it they had taken these DRW's 2wheel drive trucks and had them converted over by Marmon-Herrington. They used the MC-80 front axle (they say its comparible to a dana 80 in stength) and I think there own T-case as well..... man the front carrier is beefy!
I here the parts are a bit spendy if you need rotors ect. on front axle...will see.
Has anyone on here owned one?? I hope its not a bucket of worms, got to keep the tree business up and going.
Old 03-01-2013, 06:46 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Most likely a Dana 70.
As far as I know, No One is making rotors, so good luck
Old 03-01-2013, 06:53 PM
97F450DRW4x4
Brad, its a MC-80 made by Carrera, with 5.13 gear ratio. I here you can still get rotor and parts by calling Marmon-Herrington...but I bet its $$$$
Old 03-01-2013, 06:56 PM
97F450DRW4x4
Anybody know what DRW axle it is? ...sterling 10.5?? just checking
Old 03-01-2013, 07:02 PM
97F450DRW4x4
This is a 96' F450 that Marmon-Herrington converted to 4x4...very nice DRW truck!!!...wish mine looked this nice....
Old 03-01-2013, 07:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
where did you find that?
boy they really do set right up there don't they.i guess as long as you've got a dump trailer to load the wood in.
if your a climber,you should have an auto.you don't mind all the leg work, working and driving too? must be a young pup still or your cheating with a bucket lol. then again it's not as if you can order it your way and those converts are few and far between it seems as is.
Old 03-01-2013, 07:10 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I don't have any small Marmon trucks but I have 3 big ones. They are a decent company to deal with, lots of stuff is expensive but some is reasonable.
They buy parts from vendors so the prices reflect that. But once you find the compatible part in the parts stores, you're set.
Try finding parts for a 64 F850, a 66 F800, and an 84 F800... The new one isnt bad, the others suck. Hope you have luck.
Old 03-01-2013, 07:40 PM
97F450DRW4x4
LOL, no bucket baby here, I climb everything, and Im old.
Mainly chips will be in truck, wood once in a while.
Ya, this is a rare find, been looking for one for sometime now here in CA and pulled the trigger...
E4OD wouldnt last long in a truck like this, glad its a 5 speed
Old 03-01-2013, 07:45 PM
97F450DRW4x4
They buy parts from vendors so the prices reflect that. *******But once you find the compatible part in the parts stores, you're set******
UNTAMED, yes, I hope I can fined compatible parts from parts store, that would be nice!!....like bearings and seals ect..for front axle...thanks
Old 03-01-2013, 08:26 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Oh yeah. Forgot to say that.
I get all bearings and seals from the local industrial bearing/drive/belt place. They can match up numbers and or just measure id OD and get you what you need.
I don't know if they can get them or order them or if they make them. But look at a place called r1concepts.com
They are fairly resourceful. You may be able to give them dimensions and they can look up something for you. A friend got drilled and slotted rotors for his 1ton van and his vw vanagon. Quality is pretty nice also.
Old 03-02-2013, 02:12 AM
Phy's Avatar
Phy
Phy is offline
The rear axle is a Dana 80, with disc brakes.
Old 03-02-2013, 07:48 AM
joshh's Avatar
joshh
joshh is offline
when u get it id love to see more pics.
I work for a Marmon Harrington sister company Fontaine and have installed many 10k-22k awd conversion kits on Freightliners and some kws, Internationals and Volvo's. Would be interesting to compare to the big stuff
Old 03-02-2013, 11:07 AM
97F450DRW4x4
Phy, thanks for the info!!..glad its disc not drum
Old 03-02-2013, 11:09 AM
97F450DRW4x4
Joshh, will do my friend
Old 03-02-2013, 11:24 AM
FORDF250HDXLT
id like to go back in time and buy that blue one (or your green one now! lol) problem is,they'd still cost too much lol.nice find on those pics too.
you know what some guys do with these f-super's since they have the steep axle gearing to pull a house over,is install an aux od unit too.sometimes you can find decent deals on used ones.
Quick Reply: 97' F450 DRW 4X4 chip truck
