1959 Ford F100 Diesel Conversion Questions
I've got a 1959 Ford F100 on a 4x4 chassis. I know its not an original frame to the truck but i know its a 4x4 chassis. Possibly a 4x4 chassis from another 59'. I have a parts truck for the conversion. It is a 87' Ford F350 4x4 lariat I believe it has a 7.3L idi motor automatic trans and a gear vendors overdrive system. I am wondering if anyone here as embarked on a conversion like this. What is the easiest way to go about transplanting it? is there a engine and transmission mount already produced to get the engine and trans mounted or is that going to need to be fabricated?
Any help or suggestions would be great. Here is a picture of the 59' that I will be doing it to. I will get pictures up of the engine bay area tomorrow.
Let me be the first to welcome you! And photos on your FIRST post? Wow. And a nice clean truck, btw. OK, well I'm gonna be your ally here. I just converted my '59 to diesel. It's a long haul, with a lot of engineering and I'm not really sure the f100 frame will be adequate for that big ol' 444 cu in oil burner. Like you, I also have a '92 f350 4x4 diesel. That's a whole different animal than an f100. My conversion put a scrawny 120 hp cummins six (6at) in a '59 f350 chassis. The frame and running gear are overkill for that powerplant. So..... I would look really hard at what it would take to put the '59s cab on that parts truck. It's not easy by any means, but you'll end up with power brakes, dual master, power steering, heavy frame and running gear, frame mounted fuel tank, lots and lots of stuff people take great pains and $ to add later. Not saying it can't be done either way, but that's just my .02. I actually thought just today about putting my new parts truck cab on my '92 and building a flatbed for it. Not that I need another truck, I'm just a chronic tinkerer. I have both of your same rigs, so I can help you with measurements as well, either way. More pics please.
Thanks all for the welcomes!!!
The 59' is sitting on an 8 lug chassis. So I would assume it is a 3/4 ton chassis. correct me if I'm wrong though. The frame on the 87' is a bit longer then the frame on the 59' as the parts truck is a crew cab/long bed. Here is a picture of the front frame section on the 59'. Let me know if there are any other pictures needed. Thanks
Nab that looks to by a fridge frame.
The rear shock mounts for the front axle are not stock.
The radiator support mount stud is the type that utilizes a spring, which is seen on the 4x4's and f350 and up frames.
What is the number on the top frame rail below the battery box, and does it match the data tag on glove box door.
Is that front diff a high pinon?
I think Gary has so good info for you to consider.
Ok now I am confused. Both vin numbers match (frame and glove box). I thought the vin would start f11 if it was an f100 4x4 but it does not. But it does have the transfer case and front axle for a 4x4 setup.
So now that we know that for sure how is the engine mounting situation going to change? is it going to be harder? I heard there are companies that produce the necessary mounts to mount the engine. I'm assuming I'm going to have to be fabricating something to mount the engine.
Btw thanks for all of the help and advice thus far.
It's hard to imagine a company makes aftermarket motor mounts to put the IDI in that frame, but I've been wrong before. I'm an amature welder and I made some serious mounts to put the cummins six in mine. I just considered it part of the fun. I hate waiting for the UPS truck, so I pretty much just make everything out of scrap I have laying around. It gets done faster that way! Enjoy the process, I miss that part of my project now that I'm sealing roof seams and replacing door glass. (awful job).....
