2012 F550 tail light wiring diagram needed
Hey guys I'm in a bit of a jam here I need this truck to get to work again asap and all the searches I've done have come up with nothing useful. I need a wiring diagram for the entire tail light circuit from battery to light. The dealership is closed for the weekend but I need to get it on the road asap like I said. So if anyone can come up with a link to find one or any useful info I owe that person some beer. Thanks a million.
Received 3,108 Likes
on
Do you have a trailer towing harness on your truck? You might check to see if there is anything inside shorting the pins together. The brown wire is usually for tail lights. What you are describing is a dead short, so you could have a pinched wire, or something like snow jammed inside the plug for the harness.
