Rear Interior Cargo Light
I'm having problems with mine. It's on an 11 EL, and the switch is loose and the light doesn't work most times. You can usually make it work with the hatch up by fiddling with the 3 position switch on the light itself, but it doesn't normally stay on. Has anyone else had this problem or had to replace the light assembly?
