replacing timing gears
Yes, the 2.8 has gears, the orig. ones had a steel crank gear and a fiber cam gear, the new ones will be steel crank, and alum cam gear. They have to be installed as a set, the teeth angle is off a little and won't match well with the orig. To change the crank gear you need to drop the oil pan for enough clearance to remove the gear.
Jonathan Page
03-26-2014 12:37 PM
JRProaudio
12-16-2003 07:42 PM
