TPS screws
Old 02-05-2013, 10:29 AM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Angry TPS screws
Anyone happen to know the size and thread pitch of the screws used to hold the TPS on? After 15 years mine were stuck in and snapped, one came out with a vice-grips, the other will need to be drilled and extracted. Also, has anyone replaced them with allen-head screws or anything more robust? Anti-seize will be used when it goes back together.
Old 02-05-2013, 12:02 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
If you have to drill one out, might as well drill them both out and tap them to whatever thread you need.
Old 02-17-2013, 11:51 AM
blkF250HD's Avatar
blkF250HD
Got the screw out, my cousin TIG welded a nut to what was left of it. For those wondering, the thread size is M4x0.7. Also a bit of knowledge I picked up, the bolts holding the TB to the intake are standard (3/8" IIRC), NOT metric.
redspanhead
20
12-18-2016 08:55 AM
alchemist1
05-04-2013 08:19 PM
mpeppers
Aftermarket Products
05-25-2011 10:17 AM
CommrclDiver
Performance & General Engine Building
11-14-2007 07:32 PM
RA81222
1978 - 1996 Big Bronco
04-07-2006 10:50 PM
Quick Reply: TPS screws
