Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
07 freestyle No heat except for on high
Old 02-01-2013, 10:19 PM
Deyhey's Avatar
Deyhey
Deyhey is offline
Hi,
I have an 07 freestyle that has no heat except when its turned to the highest setting as soon as I turn it down it get cool instantly. I did change the thermostat and the old one did have a weak spring and the engine temp would drop while idling at lease now the engine will hold temp. With the temperature set to the highest settingthe air is hot the only way I can control the temp is to reduce the speed of the fan. I am now thinking it has something to do with the mixing chamber or the temperature sensor. Any ideas or suggestion would be greatly appreciated.
Deyhey
Old 02-07-2013, 09:26 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
The F150 and Explorer work like this... not sure of the Freestyle.. Hot air from the heater core and cool air from outside are mixed together in a mixing box. There is a motor controlled damper door that you adjust from open to close with the heater **** on the dash. This is called the "blend door" The larger trucks have had troubles with the control arm on the door breaking, or the electric motor drive failing. NOrmally the location is above the transmission hump, below the radio, left of the glove box. You can normally take off the plastic dash section below the radio, above the hump to get access. Some vehicles you have to remove the glove box... I hope this helps. I assume the Freestyle is similar to the Explorer..
Old 02-07-2013, 09:32 PM
steve(ill)'s Avatar
steve(ill)
when you turn the blower to HIGH- it probably pushes the loose door closed. more reading ?
Ford Explorer Ranger Enthusiasts "Serious Explorations"® - View Single Post - 3rd gen Explorer Blend Door Actuator Replacement
longt
1999 to 2016 Super Duty
03-31-2017 04:27 PM
ligito
07-28-2015 08:03 AM
cabloom300
1997 - 2003 F150
12-17-2013 09:08 PM
scountryman
1997 - 2003 F150
02-06-2011 01:40 PM
ltl_jrw
02-09-2010 06:54 AM
Quick Reply: 07 freestyle No heat except for on high
