1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Transmission adjustment
Old 01-31-2013, 12:28 PM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
Need advise; My 93' Ranger XLT extra cab 2wd, 4.0 engine and A4LD auto tranny with 126,600 miles has a rough downshift into 2nd gear about 15 or 16 mph. Down shift to 1st is real smooth and upshifting thru the gears is smooth. I just put a new modulator valve on it and it helped the upshifts smooth out, they were getting to be hard shifts before changing that valve. I do not know if there is any adjustment that can be made to smooth out the rough downshift when slowing down to a stop for red light. The U-joins are in good shape and new carrier bearing assembly on driveshaft and no extra play in the rear end. A band adjustment maybe or just have to live with it.
Old 02-01-2013, 10:00 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
There is no band adjustment to be made. The rough shift is due to excessive wear and clearances. When was the last time you replaced the fluid?
Old 02-01-2013, 10:07 AM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
Hi Khan; I changed the fluid and filter about 800 miles ago, used Mercon V. Yeah, that is the only glitch with the truck the rough down shift on 2nd gear. Every other upshift and downshift is smooth.
Old 02-06-2013, 01:07 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
Sounds like you have a solenoid issue. The rod eggs out the case. The new cases have a brass insert. I would take a look anyway.
Old 02-06-2013, 03:41 PM
dybeepvw's Avatar
dybeepvw
dybeepvw is offline
I ended up doing a band adjustment on the rear one; backed off a few turns and it is downshifting real smooth now and the upshift is also smoother so I am good with it. Thanks for the info.
Old 02-06-2013, 03:46 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
Nothing better than an easy FREE fix!
Codyb12345
10-13-2017 12:12 AM
kuli
08-24-2015 02:26 PM
speedsauto
2009 - 2014 F150
06-03-2012 11:01 AM
bobsuisun
Aerostar
02-20-2006 05:10 PM
mickf66
08-12-2004 07:44 PM
Quick Reply: Transmission adjustment
