Nebraska Chapter Join Chapter, Leader: 97nukeford
1967 thru 1972 Master Cylinder Brakes Lines
Old 01-29-2013, 09:55 PM
Mercmeister's Avatar
Mercmeister
Mercmeister is offline
Hi Guys! -
I installed a power brake booster and dual chamber master cylinder from a 1969 Ford in my 1966 Ford F100. Does anyone have a pair of donor brake lines for sale that come off the side of the master cylinder? If not, where can I can the fat brass adapters that would screw into the cast master cylinder housing to accept the standard 3/8" brake line nut?
Thank You!
Dan M.
Old 01-30-2013, 08:55 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Have you tried Napa, to see if they'd carry them? Might have to take the master cylinder in with you.
Old 02-20-2013, 04:10 PM
Mercmeister
Greetings! -
I installed a 1969 Ford F100 dual master cylinder (MC) with power brake booster in my 1966 Ford F100. If anyone is curious on the brass adapters needed to convert the MC body threaded ports to 3'8" brake lines, here are the part numbers from several manufacturers:
3/8"-24 Inverted Flare to 1/2"-20 Inverted Flare
  • AGS BLF-20
  • Edelmann 258350
  • Weatherhead 7909
  • NAPA BK 6413305
3/8"-24 Inverted Flare to 9/16"-18 Inverted Flare
  • AGS BLF-28
  • Edelmann 258302
  • Weatherhead 7911
  • NAPA BK 6413311
I bought my fittings from NAPA and they were relatively inexpensive and a perfect fit. O'Reilly's, Autozone, RockAuto, etc. will also have them. I am fairly certain these fittings will work on all 1967 through 1972 master cylinders and other years as well. Hope this helps!
Mercemeister
Three (3) 1966 Ford F100's
1966 Mercury Park Lane
Old 02-22-2013, 02:25 PM
67nukeford's Avatar
67nukeford
Nice, thanks for the info Dan!
Baby Blue
11-24-2019 07:18 PM
Fordtruck51
1961 - 1963 F100 Unibody
04-29-2012 10:46 PM
WillyB
09-15-2005 08:27 PM
fatfenders
09-14-2002 10:08 PM
Quick Reply: 1967 thru 1972 Master Cylinder Brakes Lines
