33" tires on 1995 F150 XL 2WD?
Old 01-29-2013, 04:15 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
I called my local 4 wheeling shop about installing these mods and the first thing they asked me was if I had the parts or not, seems they dont mind using your own parts. I also know that my fuel mileage is going to go down, i was just saying that I would like to keep the gears as high as possible to keep fuel efficiency as high as possible.
  #32
Old 01-29-2013, 04:19 PM
bluemtn95ford's Avatar
bluemtn95ford
bluemtn95ford is offline
I agree, I would say just have them do the alignment and supply the parts. who knows you may not need new bushings.
And yes up sizing your tires will lower mpg below your current 13-14. especially before you re-gear. Just make sure you gear it right and you will be back to similar power but still slightly lower mpg with 32's.
  #33
Old 01-29-2013, 04:20 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Your gearing logic is wrong. 4.10s would net you better milage than 3.08s in this case
  #34
Old 01-29-2013, 04:24 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
Oh I got you. Since the tires are so big, the mileage would be better with the lower gears?
  #35
Old 01-29-2013, 04:26 PM
Diesel_Brad
Correct. It would put the engine closer to is power band
  #36
Old 01-29-2013, 04:28 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
Ok that makes sense. So you think I should just get the springs and let the alignment shop worry about the bushings?
  #37
Old 01-29-2013, 04:30 PM
bluemtn95ford
Keeping high gears won't necessarily keep your mpg higher. If you have high gears your motor will have to produce more power to turn the tires, which, of course uses more gas. LOWER gears will convert the power of the motor better and so turn the tires easier, but you will still use more gas because the gears require more turning, thus giving you more power, but still less mpg. I think this is how it works, again there are some guys on this site with WAY more experience on gearing than me.
  #38
Old 01-29-2013, 04:33 PM
bluemtn95ford
Yes, let them do the worrying lol
  #39
Old 01-29-2013, 04:35 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
Haha I don't know if I want to because then I'll be the one worrying when they come out with the bill!
  #40
Old 01-29-2013, 04:53 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
So in your opinion, I should just get the springs, install them myself, then take it to an alignment shop and let them take care of the rest?
  #41
Ryan0214's Avatar
Ryan0214
Ryan0214 is offline
My understanding is that, with lower gears, your engine will transfer the power better, resulting in slightly better mpg, but the faster you go, the more your engine will be revving, resulting in lower mpg. Higher gears are better for cruising at higher speeds, but lower gears are better for torque.
  #42
Old 01-29-2013, 05:48 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
A few things of note:
Nobody is bashing you for not knowing everything. That's why forums like this exist, for information and help when you need it. It's also a place that can pass misinformation, such as installing F250 leaf springs on the front of your 2WD. Simply put, that's a horrible idea.
Your idea of installing the springs and letting the shop worry about the camber bushings is correct. Camber bushings can be a pain in the *** to get out, even with air tools and torches.
Check with the shop doing the work, to compare pricing of you bringing them parts to install, and them supplying parts and labor. Many shops will charge a higher labor rate to install parts that you bring them, and sometimes you end up not really saving much money at all.
You're going to hate the acceleration of your truck with 3.08 gears and 32" tires. Also, what Brad mentioned is exactly correct. Your fuel mileage will improve with 4.10s, simply because it puts the engine in the correct powerband. Larger diameter tires numerically lower your final drive ratio. It's a lot to explain, but perhaps a google search of "final drive ratio" or something like that would turn up an article or writeup that would be helpful.
  #43
Old 01-29-2013, 06:12 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
Thanks Bob, I will go ahead and order the springs. I'll keep y'all posted!
  #44
Old 01-29-2013, 06:16 PM
Bob Gervais
Looking forward to seeing it done! There is another member here with a lifted 2wd Flareside that looked great. I haven't seen him post in a while.
  #45
Old 01-29-2013, 06:19 PM
CoreLokt's Avatar
CoreLokt
CoreLokt is offline
Ok the springs are officially ordered. Are there any other things I should look to have to replace before I can be aligned? I know when I took our Expedition, they said it needed new ball joints before they could align it so we got some and installed them ourselves.
Quick Reply: 33" tires on 1995 F150 XL 2WD?
