Tax Time!
Old 01-27-2013, 01:25 PM
chamblizi's Avatar
chamblizi
chamblizi is offline
Tax Time!
Sup its phil I would like to know on average how much would it cost to Rebuild My engine on my ranchero Its tax time and right now i am running a scrap hauling business with my ranchero.
I am thinking relativity it should be expensive but inexpensive. I also have to find a new noise supressor for my alternator because i get feed back from my amplifier. in my stereo.
Old 01-27-2013, 01:32 PM
CB28424's Avatar
CB28424
CB28424 is offline
Well first we need to know what engine you have?
Old 01-27-2013, 03:45 PM
tbirdscott's Avatar
tbirdscott
tbirdscott is offline
Wow, havent been to this forum in months. Lo and behold Philly still be trollin...
Old 01-27-2013, 04:00 PM
CB28424's Avatar
CB28424
CB28424 is offline
Tou could power your AMP straight from the battery through a toggle switch and ground it as well from the battery and you will loose all the back feed from alternator, just a thought.
Old 01-28-2013, 12:07 AM
parts4me's Avatar
parts4me
parts4me is offline
Run your power straight from the battery. Put an in-line fuse and use a capacitor for the system. I haven't had an issue doing that.
What are you all wanting to do in the rebuild? Adding any aftermarket stuff or just rebuilding what you got on it?
Old 01-31-2013, 04:26 PM
chamblizi's Avatar
chamblizi
400m but i decided to get a new truck its too small for my scrap business... I need at least a bed that can fit up to 500 pounds + scrap steel and a couple of 100 pounds of copper... going back to ye ol f series.
Old 01-31-2013, 04:28 PM
chamblizi's Avatar
chamblizi
ok first off drop the stuff at the door avoided.... I got bigger plans then your bs i got a family now. If you cannot act like a adult then don't post....
Old 01-31-2013, 04:31 PM
chamblizi's Avatar
chamblizi
not sure now but i changed my mind I just need to upgrade to F series again. My system was hooked up by me and was done with the proper prosedure on the paper work when i got the kit.
My wife's professionally installed stereo is doing it now too.. our area we live in must have some type of weird magnetic pole.
Old 02-02-2013, 02:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
D5AZ-18832-A (replaced C6OZ-18832-A) .. Capacitor-Radio Voltage Regulator-Located on Voltage Regulator for radio/ignition interference.
All 1966/80 FoMoCo Passenger Cars/Trucks/Bronco's/Econolines.
D5AZ-18832-B .. Capacitor-Radio Voltage Regulator-Located on alternator.
1975/78 LTD/Mercury Grand Marquis / 1978 LTD II/Bronco.
68bluebeast
11-05-2015 02:49 PM
DCRB
Aerostar
04-10-2008 05:18 AM
Mike's 77
18
03-11-2008 05:53 PM
justine's77ford
01-09-2007 03:22 PM
fordtuff33
01-02-2007 06:33 PM
Quick Reply: Tax Time!
