Michigan Chapter Join Chapter, Leader: Toyman
Extremely bad news for my truck
Old 01-21-2013, 05:28 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
Last week I had some things taken care of on my truck. I replaced the ECT, EOT and EBP sensors. In the process of moving the degas bottle, we accidentally cracked the Y hose that attaches to the degas bottle. No big deal as I had an instance of coolant puking after doing the coolant flush and installing the coolant filter. I was pretty sure that the puking was the result of over filling it. I didn't have another issue until today......
Driving down to Grand Rapids, I stopped in Rockford to pick up a turbo for my 7.3. That's when I noticed coolant on the snow. I popped the hood and saw where coolant had come out of the degas bottle. Obviously I am bummed, but the story doesn't end there. I knew I was being vigilant watching all my temperatures and never saw anything out of wack. I drove home and found out that when distance to empty says 0, it means it. I coasted into the gas station in Cadillac and filled it up. Didn't see any signs of pukage so I drove to my parents house a half hour away. I went inside for about a half hour with the truck idling. When I came out I noticed more puking. I looked and this time it spewed out the degas as well as both endcaps of the radiator! I'm so screwed. I can't afford to fix it for now. I think Rich replaced his radiator and it wasn't cheap.
So let me know what you think? How screwed am I?
By the way, my 4" exhaust and SCT tuner helped me get almost 15 mpg round trip.
Old 01-21-2013, 07:34 PM
FordBlueHeart
No one has any ideas?
Old 01-21-2013, 11:30 PM
Chad149's Avatar
Chad149
Chad149 is offline
Sounds like your getting pressure build up in your cooling system. Head gaskets are a possibility. Don't the egr coolers sometimes fail and let drive pressure build in the cooling system?
Old 01-22-2013, 06:54 AM
bbender85's Avatar
bbender85
bbender85 is offline
i wouldn't rule head gasket out either. have you checked the oil for milkiness and the coolant for oilyness? i would definitely post this in the 6.0 section.
Old 01-22-2013, 08:44 AM
FordBlueHeart
Both of you are thinking the same thing as me. I haven't checked yet as it was too cold last night. I think im most concerned about the radiator at this point. I can budget for studs, gaskets and delete, but the radiator is too much.
Old 01-23-2013, 02:21 PM
bbender85's Avatar
bbender85
get anywhere with this torr?
Old 01-24-2013, 07:49 AM
FordBlueHeart
Nothing so far. I dropped it off at the body shop to have some physical damage taken care of while I formulate a plan of attack on the mechanical issues.
Looks like studs, gaskets, oil cooler and other things are going to happen sooner than I thought.
Old 01-24-2013, 01:42 PM
Toyman's Avatar
Toyman
Toyman is offline
That's exactly what mine did. The pressure build up popped the seal on the radiator tanks. Ended up being headgasket, which if everyone remembers the story was the second time for them in 6 months due to improper installation. Pioneer Diesel right by you fixed me up.
It really is eally is best to do studs, oil cooler, egr delete while it's opened up. Just be sure to do the proper torque sequence and it should never come apart after.
There is a radiator place that was up there, wish I could remember the name, that can probably get the tank seals and repair your radiator with out having to replace it. I was in a time crunch and HAD to have the truck cuz I was just getting ready to move down state.
Good luck man...
Old 01-24-2013, 07:39 PM
FordBlueHeart
I think it was Coyle's Radiator, but I'm not sure. I can get a brand new Ford radiator for a little over $300. I have a good friend who is the 6.0 tech at the Ford dealer. So far he installed or replaced my ECT, EOT, EBP sensors, 4" MBRP exhaust, coolant Y pipe and reflashed my PCM, TCM, and FICM for $90!
Old 01-24-2013, 07:55 PM
Toyman's Avatar
Toyman
Toyman is offline
Yep, that was it. It's in an industrial area, nice guy that owns it. It's nice having a friend that can do that for ya, and someone that works on em so you know that he knows what he's doing.
Old 01-24-2013, 08:31 PM
FordBlueHeart
Exactly. Jason is an extremely nice guy. He has a yellow Torino as well as his early '99 super cab 7.3.
Arlo2131
02-16-2017 05:37 PM
ElMoco
46
11-28-2016 09:42 PM
biggercb
1997 - 2003 F150
11-19-2012 10:36 AM
Mr. Bob
12-19-2006 07:44 PM
95xltmud
07-06-2002 09:19 PM
Quick Reply: Extremely bad news for my truck
