glass identity
glass identity
hoping some of you ford guru's can tell me if this glass belongs to a Econoline? cargo van? or even belong to the van of question?
the glass has a carlite stamp on the lower corner
#1 line "solid safety glass"
#2 "Carlite"
#3 "tempered"
#4 "7k sun-x as2
#5 dot-75 fm-m65
In my research my finding that 7k = the glass was made in oct-1967
as2 = secondary glass
dot-75 = it was made dearborn mich.
fm = ford motor company .
m65??? still a mystery
measurements are as follows 24" long by 14 1/2 height , its a curved glass , tinted green , with a chrome trim surrounding check out photos from photobucket and thank you for your time
rjg8819's Library | Photobucket
#2 "Carlite"
#3 "tempered"
#4 "7k sun-x as2
#5 dot-75 fm-m65
This is definitely an"automotive conversation"
Maybe a mod will move it to the '61-'67 Econoline forum?
Ranchero & 1961 - 1967 Econoline - Ford Truck Enthusiasts Forums
Originally Posted by rjg8819
In my research, my finding is that 7K = the glass was made oct 1967.
DOT: US Department of Transportation. DOT numbers will be found on lamps, tires, glass and a gazillion other parts.
If the glass was actually made 7/1967 (I have my doubts), it most likely would have been installed on a 1969 Econoline (intro'd 2/1968).
Hinged ('pop-out') glass like this was used on the right/left side doors and back doors of 1961 and later Econolines, but I don't recall this glass being curved.
The handles were chrome 1969/74, 1975/91.
found this quote from another forum
"The dates on glass are year/month format, so the 7H would be August, 1967(7 is for '67, H is the 8th letter which decodes to the 8th month, August). For skipped 'I', so September would be 'J' "
also thinking it was in line for a econline , but the plastic blk hinge/latch to open the vent/wing glass doesnt fit to me , should be chrome ...
mystery solved hows this look all
After some poking around I found that the code could be 1967, 1977 or 1987.
It appears to be the middle side window of one of these:
Ford Pinto Squire Wagon 1977 images
Mystery solved. After some poking around I found that the code could be 1967, 1977 or 1987. It appears to be the middle side (quarter) window of one of these: Ford Pinto Squire Wagon 1977 images
The bushings used with these windows is the same as 1975/79 Super Cabs with movable quarter windows.
Aus56
09-09-2012 03:38 PM
rla337
05-06-2008 05:01 PM
