35" tires?
I had a 2011 f250 6.2 (moved to a 12 psd now) I have run 325/65/18s on both trucks. Those tires are 35" tall and probably about 12" wide. They fit fine but I would get a little rub on the on the passenger side when the wheels were turned all the way to the right.
On the gasser I trimmed the plastic wheel well a little and fixed it on the new 6.7 I installed a 2" leveling kit and it fixed it.
Hope that helps
Hope that helps
I have these on my truck, and they fit fine with no rubbing at all, even at full lock with the suspension articulated in either direction. I have no lift added, but the front end does have the snow plow prep package, so the springs may make it sit a little bit higher.
Those tires are a Load Range D, not E. Also with a Max of 50 psi, doesn't your TPMS go off? You are losing 600lbs per tire of payload allowed. Plus they are only 34.7" too, not really 35's. I was looking at the Duratrac's in 305-70-18 and found out they would rub at full turn so I opted for the stock size as I did not want a lift.
at all. And again, I checked mine at full lock in both directions with the frame articulated on steep bank.
DUVALL
01-05-2004 02:35 PM
