whacky liftgate
Old 01-06-2013, 06:10 PM
jawdoc's Avatar
jawdoc
jawdoc is offline
whacky liftgate
ok the power lift gate on my 08 Expedition started to do this crazy thing...
when you press the button to close the gate it closes almost all the way and ready to latch then it opens back up again.
Then it finally stopped working completely. Fuses all check fine. I pulled the motor and bench tested it and it worked fine.
Re-installed motor and same thing...it wont close.
Any thought??
Old 04-06-2013, 06:34 PM
2LMAKER's Avatar
2LMAKER
2LMAKER is offline
Find a fix?
My 08 started doing this today. Only difference I noticed was squeaking sound as it closed earlier in the day. Then when I got home it started doing the almost closing then opening back up. Only way I got it to close was stop it as reopened it would slam shut.
Thanks
Old 04-12-2013, 09:23 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
Any thought??
Motor will test fine on a bench because there's no resistance. That being said 90% of the issues found with these are the motors. They reverse based on resistance and loading.
Old 06-07-2013, 05:54 PM
gears351's Avatar
gears351
gears351 is offline
So did you get this fixed or are you still trying to figure it out?
My 07 randomly opens itself and after "fixing" that problem by disabling the rear access I can now only open the gate with the key fob. Liftgate handle doesn't work..... Before, you'd hear the latch actuator when you pulled the liftgate handle, now there's nothing and the gate won't open manually.
MooManChu
2017+ Super Duty
05-12-2019 11:47 AM
PwerStroke99
2017+ Super Duty
11-28-2016 08:17 PM
Jaylegger
03-10-2013 09:44 PM
SMS888
12-03-2012 08:08 PM
Redneck1465
07-06-2009 03:21 PM
Quick Reply: whacky liftgate
