2" of play in steering wheel
Is 2" of play in my steering wheel normal? Is there any other adjustment I can make? The front checked out ok, state inspection. Before adjusting the gearbox (nut) a little. It was two hands on the wheel at all times. The gearbox never leaked and it's not to bad to drive with one hand, now.
Thanks,
93 f510 150,000
Thanks,
93 f510 150,000
My truck always had this problem, even before the lift. I have replaced all ball joints, tie rod ends, draglinks, had a professional alignment, tightened all connections to and from the gear box/pitman arm. All that for nothing. When other people drive it they say its all over the road and unbearable but im use to it.
My truck always had this problem, even before the lift. I have replaced all ball joints, tie rod ends, drag links, had a professional alignment, tightened all connections to and from the gear box/ pitman arm. All that for nothing. When other people drive it they say its all over the road and unbearable but im use to it.
To mike L. I wouldn't put much faith in that STATE INSPECTION you mentioned. I'm betting you have a worn basic steering component. Either the drag link or a tie rod end or closely associated part.
Turn your ignition switch to unlock the steering wheel, DO NOT START THE ENGINE. Get an assistant to slowly turn the steering wheel back and forth about three inches. Crawl under the truck and closely watch the stuff I mentioned above for play.
It was worth doing! I had to drive with both hands before, now just one hand. I loosened the nut and turned the screw to the right to tightening the steering. I went 1/8" at a time. I heard don't go to much!! ?????? Post a new question first with adjusting steering gear box. The guys answer right away. I found out every little problem i have with the truck there's always good answer here.
Yeah, you want to take your time tighting the steering box nut. If you go too far it will wear the box completely out faster.
It also makes the truck steer hard, you get bump steer and will drive really strangely, dangerous even.
Also, it seems more difficult to get the adjuster to back off than tighten down, so sneaking up on it is easier.
Technically you really aren't supposed to change the lash or preload on a steering box after its inital adjustment except when rebuilding the box, but I've known people to tighten it up and drive for years.
Shortybr549
29
08-17-2017 05:07 PM
midsouth
11-12-2011 08:17 PM
chazman_1962
05-17-2007 04:08 PM
