Australia Chapter Join Chapter , Leader: ChunderDownUnder
1993 - 1997 RHD diesel
Old 01-01-2013, 07:23 AM
4x4falcon's Avatar
4x4falcon
4x4falcon is offline
Did ford import any 7.3 diesel F series in 1993 - 1997 as right hand drive?
Or does anyone have one?
If so can you post a picture of the steering box and steering column in the engine bay showing their relation to the exhaust manifold on that side.
TIA
Old 01-01-2013, 09:35 PM
BigF350's Avatar
BigF350
BigF350 is offline
None were officially imported, with the exception of some conversions of US models that were Ambulances.
Old 01-01-2013, 09:40 PM
4x4falcon's Avatar
4x4falcon
Thanks.
Thought that was the case.
Have an issue with my steering column, steering box with the exhaust manifold being in the way but I think I've worked out a solution.
Old 01-02-2013, 04:01 AM
aussie_f350's Avatar
aussie_f350
aussie_f350 is offline
there are a heap of mid 90s ambos here, may try find one for sale and check that out?? i sold my idi f250 a few months ago otherwise i could of helped ya, sorry
Old 01-02-2013, 04:50 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
What ever you come up with can't be any worse than the Ford Australia solution to the RHD 7.3 TD F250 set up - i.e. TWO steering boxes, the FA added RH one 'driving' the original LH one. A system with alledged 'designed in vagueness' so vague (4%) that apparently it needed special dispensation from the steering accuaracy standard of the day (1%).
So you should end up with the best steering RHD 7.3 on the planet!
Old 01-02-2013, 04:26 PM
4x4falcon's Avatar
4x4falcon
Looking at using components from here
Borgeson
Single uni at the top and double uni to get around the exhaust manifold at the bottom. Shaft with support in between.
Still won't be able to use the mechanical fuel pump as the steering box and it can't occupy the same space.
I'm going to wait until I've got the cab transferred then look at what will work.
Old 01-02-2013, 07:49 PM
BigF350's Avatar
BigF350
BigF350 is offline
Just go full hydro, don't need to worry about a steering shaft
Wildcat Fords
04-29-2017 09:35 PM
mark63uni
1961 - 1963 F100 Unibody
03-06-2012 08:35 PM
handx2
05-27-2004 07:16 AM
Quick Reply: 1993 - 1997 RHD diesel
