Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
1997 - 2012 Ford F150 Truck 4 Wheel Drive Solenoid Pair with Cover
Old 12-27-2012, 03:38 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
SHOP HERE: 1997 - 2012 Ford F150 Truck 4 Wheel Drive Solenoid Pair with Cover
These 4X4 Solenoids are just what you need to get your four wheel drive system working again! The factory solenoids commonly fail due to cracking and leaking, resulting in failure of the four wheel drive system.
Specifications
Includes both engagement & disengagement solenoids
splash cover included
Correct electrical connections
Replaces dealer part numbers: 6L3Z9H465A, 6L3Z 9H465 A, 6L3Z9H465B, 6L3Z 9H465B
Durable construction
Direct bolt on replacements
Built to strict quality control standards
Note: There are two solenoids located side by side in the housing; engagement & disengagement. The simple way to know which is which is the key way location: holding the solenoid with the connector at the top and vacuum lines on the bottom, the engagement solenoid key way will be at the 9 o'clock position (to the left), the disengagement solenoid key way will be at the 6 o'clock position (bottom).
If one of the two solenoids fail, the 4 wheel drive system will be inoperative. Both solenoids must be functioning properly for the system to operate.
1Aauto
03-28-2018 03:07 PM
1Aauto
03-28-2018 02:52 PM
1Aauto
09-21-2016 02:34 PM
chillyd2008
New Member Introductions
04-20-2008 11:19 AM
paul burak
11-25-2007 09:11 AM
Quick Reply: 1997 - 2012 Ford F150 Truck 4 Wheel Drive Solenoid Pair with Cover
