1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Adding Power Brakes to my '63
Old 12-26-2012, 11:03 AM
prndl's Avatar
prndl
prndl is offline
Is there an easy way to add a power brake master cylinder and booster to my '63. My truck originally had a standard M/C with one line out to all four wheels.
I would like to change it out to a dual M/C system with a vac booster. I still have drum brakes on all four wheels. Will this be a problem with a dual M/C setup? Will I need to install a bias system or balancer with the dual M/C?
Old 12-26-2012, 04:13 PM
William's Avatar
William
William is offline
On line kit includes the MC, booster and splitter valve for a drum/drum system. Check out master power brakes or any of a half dozen suppliers.
Old 12-27-2012, 01:54 PM
pburress's Avatar
pburress
pburress is offline
I did exactly this on my '63. I bought the $300 Booster/dual master cylinder kit from Classic Performance Products and it bolted right up to the firewall and brake pedal. You will need to split front/back lines from where they converge to separate the front and back. I got everything I needed to complete it from my nearest chain parts store. You will not need a proportional valve if you are keeping it drum/drum, as I did. This is a huge improvement and pretty easy to do. While you're doing it I'd suggest you replace all four wheel cylinders and if you have the single-piston front wheel cylinders, replace these with dual-piston cylinders.
Here's a link to my brakes thread where I talk about all this and more: https://www.ford-trucks.com/forums/1...questions.html
Old 12-27-2012, 06:14 PM
prndl's Avatar
prndl
prndl is offline
Thank you for your help.
After all the forums i belong to you would think I would remember to use the search function
Chef Tim
07-23-2015 01:09 PM
angrymade
05-09-2013 05:24 AM
66F100Again
03-09-2007 03:36 AM
wiskey63
08-01-2002 09:14 PM
44dwarf
13
01-21-2002 07:11 AM
Quick Reply: Adding Power Brakes to my '63
