Tire pressure monitor problems
Old 12-19-2012, 11:55 AM
deputypq920's Avatar
deputypq920
deputypq920 is offline
Today on the way to work the tire pressure idiot light began to blink and a message came on and said "Tire Pressure Monitor Failure" or words to that effect. About a minute later they both went off and didn't come back on. Whats up with that? Also, how do I know which monitor, if any, is going out?
This on a 09 Screw with 49K on it.
Old 12-19-2012, 12:49 PM
FORDSVTPARTS's Avatar
FORDSVTPARTS
FORDSVTPARTS is offline
Former Vendor
Did you check your tire pressures?
Old 12-19-2012, 01:33 PM
deputypq920
No, I havn't had a chance to put a guage to them yet, but they look normal. I'll check that when I get home.
Old 12-19-2012, 07:35 PM
awq134's Avatar
awq134
awq134 is offline
i didn't know that 2009's had the tpms. is it just on certain models? I have a 2010 STX that doesn't have it. I'm kind of glad that it doesn't have it. The wife's car had a sensor go bad so there was always a light on the gauge cluster blinking.
Old 12-19-2012, 08:28 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
Does your spare tire look normal too?
My little brothers 08 STX had the light come on and his spare tire was low on air.
Old 12-19-2012, 08:48 PM
Going_Going_Gone's Avatar
Going_Going_Gone
Going_Going_Gone is offline
The other morning it cooled off overnight and my son's and my trucks had TPMS lights go on. The day before it was warm enough to not trigger the light, but the sudden cool-down brought the pressure down enough. I checked my pressures, all were low, but one of them was down to 25 psi. My guess is that your tire(s) were just at the low pressure limit that triggers the light...then driving it warmed them up enough to expand the air and the light went off.
Old 12-20-2012, 04:38 AM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
Well you either have a low tire pressure or one of the sensors needs replacement. The batteries on them usually last about 3-4 years before needing replacement.
Old 12-20-2012, 05:57 AM
Chris Anchor's Avatar
Chris Anchor
Chris Anchor is offline
You can have the dealership set the monitor level to a different PSI. I did as I wanted my monitor to tell me at 50 PSI. I inflate mine to 55 lbs, I prefer a harder ride. Chris
Old 12-20-2012, 07:14 AM
deputypq920
I checked the pressures last night and all were fine, including the spare. The weather here has been rather warm, 75 degrees in the afternoons, though a cold front is coming through today. The wierd part was that the sensor blinked, and it gave a sensor problem warning message. I had been driving about 20 minutes at 40-50mph. Also, how do I tell which sensor may be going out? On my friend's Chevy it tells you which tire is low. This is just a non specific warning. I don't want to change all five of them if only one is bad.
Old 12-20-2012, 08:13 AM
PrinceValium
The dealer can tell you which one it is.
Old 12-20-2012, 09:22 AM
stephen.osborne1's Avatar
stephen.osborne1
stephen.osborne1 is offline
I've had the same problem... I figured it was due to radio interference, as each time it has gone off, I was going through a city. I was not aware that the dealer could change the pressure level for it to signal at... I think I'll have to have my dealer adjust mine, as I have Toyos on my truck and I like a little harder ride too.
Old 12-20-2012, 10:48 AM
Jimbits78's Avatar
Jimbits78
Jimbits78 is offline
It's not tire pressure. If it was it would say low tire
I have the same thing happen on my 2010 every 5-6 weeks. It will show the tire monitor fault for a few minutes then go out. This started happening after the tire shop switched my sensors over to my new rims.
Old 12-20-2012, 02:34 PM
deputypq920
I'm certain they can, for $50 an hour. I don't like the Ford service department near my house, especially since they literally left me out in the cold once before.
Old 12-21-2012, 09:19 PM
wwilson43's Avatar
wwilson43
wwilson43 is offline
TPMS became mandatory in the 07 models, your 2010 STX does have it unless you bought the truck used and someone changed out the rims
Old 12-21-2012, 11:25 PM
PrinceValium
$50 an hour would be cheap here!!
Quick Reply: Tire pressure monitor problems
