1958 F100: confusing items under hood?
Old 12-14-2012, 10:44 AM
msauls's Avatar
msauls
msauls is offline
Hello, new here with a (newly acquired) '58 F100 272 Y-block.
I'm puzzled at some of the findings tho- I hope someone here can perhaps shed some light.
I found a three prong plug sticking out from under the hood and chased it to this small canister and hoses? Anyone know what this stuff is?...or what it should be?
The plug
Traced back to this on the right side fenderwell. The plug wire goes into the lower portion of this small upright canister
Overall, you can see the hoses...one plugged, etc
Old 12-14-2012, 11:27 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Welcome to FTE.
Those are the likely remains of a now-deceased cooling system warming and recirculating pump.It was installed in-line in a heater hose to prevent the engine block from freezing up.
Steve
Old 12-14-2012, 11:53 AM
msauls's Avatar
msauls
msauls is offline
Thanks! So I'm assuming this is no longer needed. Should those hoses be connected to something original?
I haven't received my shop manual yet so I'm not sure what is supposed to be.
Old 12-14-2012, 12:07 PM
3414's Avatar
3414
3414 is offline
That is an aftermarket coolant heater. It will not show up in the shop manual.
I notice that your heater core is bypassed (hose goes from water pump to engine). So you have no flow to the in cab heater. Mormally an aftermarket coolant heater is spliced into one of the lines leading to the heater. This is not needed unless tou like to have a pre heated truck on cold mornings.
Old 12-15-2012, 05:02 PM
msauls's Avatar
msauls
msauls is offline
Thanks again, Steve and 3414. All and any info is appreciated!
I'll try to get it back to normal without the aftermarket coolant heater. Truthfully I may end up omitting the heater here in TX.... But we'll see. Thanks!
Old 12-15-2012, 06:56 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
More then likely someone disconnected the heater because the core leaked.
Nicmike
12-09-2019 01:42 AM
Mixer man
06-13-2015 11:04 PM
AtlM5
01-07-2015 07:14 PM
sunbelt57
12-04-2014 07:28 PM
victorcharlie
11-21-2011 03:31 AM
Quick Reply: 1958 F100: confusing items under hood?
