Axles
Old 12-08-2012, 06:29 PM
jjurva!'s Avatar
jjurva!
jjurva! is offline
Axles
The axle on my truck, 1960 f100 4x4, snapped to the right of the differential. I welded it together so i could move it around my yard and needless to say I need a new axle. I found a 59 f100 i could buy for relatively cheap. Can I pull the third member and put my gears into the new axle from the new truck and put that on my truck?
Old 12-08-2012, 07:31 PM
spurredon's Avatar
spurredon
spurredon is offline
If you are talking about "an axel shaft", that broke, why not just swap one from the '59 and save yourself a lot of work. If you are talking about "an axel housing", the hollow tube which the axel goes into, in answer to your question, yes!
Old 12-08-2012, 09:21 PM
jjurva!'s Avatar
jjurva!
jjurva! is offline
The housing broke. The shafts and gears are fine. Thanks! I looked at it today and when I got there I wasn't sure what to look for. The housing looked similar but I just didn't know if it would work. I can finally get my truck back on the road! Also the new axle housing has spring welded to it. Is this a problem? Can I just grind them off?
Old 12-08-2012, 10:19 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Whaaaat? Just don't reuse the springs!. Welding the springs to the rear axles? Suddenly I don't feel like such a hack.......
Old 12-08-2012, 10:38 PM
jjurva!'s Avatar
jjurva!
jjurva! is offline
I was a little surprised to see someone had done that. They didn't weld the leaf springs to the truck but to the inside of the leaf spring they have a regular helix spring welded from the axle housing to the chassis.
jrockdiddy
06-21-2013 10:57 AM
Dano78
27
04-17-2011 04:08 AM
Kevin Gaudreau
2004 - 2008 F150
11-29-2010 12:38 PM
gahi
07-27-2004 07:54 PM
rebelford
1978 - 1996 Big Bronco
16
06-26-2002 07:49 PM
Quick Reply: Axles
