Roof Seam
Old 11-17-2012, 07:36 PM
mixup's Avatar
mixup
mixup is offline
Roof Seam
What do you use to fill in the seam around the back of the roof on a 60 F100
Old 11-17-2012, 08:38 PM
oldebrush's Avatar
oldebrush
oldebrush is offline
Roof Seam
Well, Most bodymen would use a product like "3M Body Seam Sealer". It's flexible, paintable and comes both in a tube (like weatherstrip adhesive) or brushable from a quart can. May be available in pints too, but for what you are asking, the tube should be sufficient. I'll be using it on mine when ready.
Aloha
Old 11-17-2012, 08:49 PM
economan's Avatar
economan
economan is offline
A specific seam sealer is available @ any auto parts store that carries autobody supplies.
if you are not particularly a steady hand at operating a caulking gun, or don't have a power caulking gun available to you I recommend masking tape on both sides of the seam, apply the sealer and using a rag that is well soaked with solvent wipe over the freshly applied sealer to smooth it and help push in to the crack. Then proceed to remove the tape right away whilst everything is still wet so you dont get any ridges on the seam sealer.
Oh ya.... by the way make sure that the inside of the seam is nice & clean, free of rust and primed before applying the sealer. Finish over the sealer with whatever primer you are using and you are ready for your topcoat.
AAAAnnnnndddd.......
Don't forget to check how the factory seam sealer islookin' inside the drip rails, with it being over 50 yrs. old it's likely pretty dried & cracked, you probably should freshen this area up whilst you are at it. As well as the seam between your boxside & taillight panel if it's a styleside box.
Mikie near ottawa canada
58 M-100 panel & 64 Econoline p/u
Old 11-17-2012, 08:51 PM
mixup's Avatar
mixup
mixup is offline
Thanks, I have a couple of tubes of seam sealer from another project. I just thought it was going to run out because the sealer is not thick.
jpcnorthwood
Paint & Bodywork
24
04-16-2017 05:42 AM
77red4x4
Paint & Bodywork
19
10-25-2006 05:55 PM
hacking_in2002
Paint & Bodywork
06-01-2006 05:26 PM
F250Rob
08-08-2004 07:57 PM
Matts68f100
04-12-2003 03:06 PM
Quick Reply: Roof Seam
