New TSB for the CAC on the Ecoboost confirmed!!!
Old 11-14-2012, 01:50 PM
moosesp's Avatar
moosesp
moosesp is offline
My dealer confirmed today that there is a new TSB for the charge air cooler (intercooler) on the ecoboost motors for the problems they have been having with condensation buildup. I have had this problem myself and I am happy that ford has stepped up and has redesigened the intercooler.
Hopefully this is the final fix for the issue. From what the service manager has told me, they are replacing the intercooler with a redesigned unit that will eliminate condensation build up under certain conditions. (Driving at a constant speed for a long period of time under certain temperature and humitdity conditions). Hope this is the final fix.
Old 11-14-2012, 03:31 PM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
hope your right!
Old 11-14-2012, 11:27 PM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
That sounds great! Hopefully any new truck being made will have the updated intercooler!
Old 11-16-2012, 12:27 PM
chambers's Avatar
chambers
chambers is offline
This is exactly the same issues the 6.4 owners have with the F250 diesels . Ford came out with a "redesigned" CAC, which was supposed to cure all problems. It didn't. I still have the problem after 5 yrs. and three CACs
Old 11-17-2012, 11:35 AM
moosesp's Avatar
moosesp
moosesp is offline
The New TSB number is 12-10-19 if anyone is interested.
Old 11-17-2012, 11:51 AM
moosesp's Avatar
moosesp
moosesp is offline
Sorry to here about your problems with the 6.4 liter diesel. There is a great article in the new Diesel Power about the problems and fixes for the 6.4 liter diesel. I thought you might be interested in it.
Have you had any issues with the 3.5 liter ecoboost in your Lincoln?
Old 11-17-2012, 12:14 PM
chambers's Avatar
chambers
chambers is offline
Have you had any issues with the 3.5 liter ecoboost in your Lincoln?[/quote]
Absolutely no issues with the ecoboost in the Lincoln...tremendous power,good performance, decent mileage (23 mpg)
I will have a lookin the link you provided, see if they have any new info.Thanks
Old 11-18-2012, 11:51 AM
Jpuff's Avatar
Jpuff
Jpuff is offline
I have a 2012 F150 Ecoboost and I seem you talking about this and I was wondering is there away I can tell if mine is the old or new CAC / TSB. I'm new to the Ecoboost and so far I'm loving this truck. I got 3100 miles on it. Also my father has the same truck. I want to know also so I can let him know about it. Thanks.
Old 11-20-2012, 06:55 PM
wwest's Avatar
wwest
wwest is offline
"..will eliminate condensation build up under certain conditions.."
A bit of double-speak...
That's the same factory line that was used for the shield/firmware update that quite clearly only worked UNDER CERTAIN CONDITIONS.
Plus the FACT that the CAC itself was not the real, bottom line, problem, EVER.
It was AlWAYS the pressure drop across the CAC, inlet to outlet, that resulted in condensation Under certain conditions.
The ONLY answer as I see it is to avoid, in simple cruise mode (N/A mode?), having the turboes already spun up to a level that results in that pressure drop across the CAC.
Old 11-20-2012, 07:02 PM
wwest's Avatar
wwest
wwest is offline
The FWD or F/awd Lincoln is never expected to tow 3+ tons "smoothly" nor does it have RWD combined with the LIGHT ***-endedness of a PU.
There is a reason the SHO only comes with F/awd, restrict that level of torque to only the front wheels, turn off TC, and you're in for a WILD Ride. But I would expect that any FWD EcoBoost would have the engine automatically detuned in all of the lower gear ratios.
Can you actually turn off TC in the SHO?
I would bet not, or else the SHO engine gets severely derated/detuned with TC off.
Old 11-21-2012, 11:39 AM
wwest's Avatar
wwest
wwest is offline
My best guess would be that the new CAC has increased crossflow, flow volume, capability such that there is no pressure drop across the CAC as long as the intake airflow is not above the range required for simple cruise (no TOW) speeds up to ~75MPH.
No pressure drop, NO condensation.
MikeD78
EcoBoost (all engine sizes)
09-08-2015 05:05 PM
makuloco2000
2009 - 2014 F150
03-08-2014 01:26 PM
Simmy150
2009 - 2014 F150
12-27-2012 06:42 PM
thomastl
11-05-2012 07:50 AM
hcfr34
General Automotive Discussion
01-06-2006 06:45 AM
Quick Reply: New TSB for the CAC on the Ecoboost confirmed!!!
