cectane level: diesel v.s. oil
Old 11-08-2012, 08:33 PM
1989f250IDI's Avatar
1989f250IDI
1989f250IDI is offline
if i run straight diesel v.s. Diesel with a gallon of oil in it which has a higher cectane level
Old 11-12-2012, 08:29 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
since cetane rating is how readily the fuel ignites, i suspect the straight diesel would be better in that regard. but i'm no scientist when it comes to this.
i've run as much as 20% oil in my diesel with good results, i would say you're totally fine running even a few gallons oil per tank of fuel, though i can't say what it does to the cetane rating. but if it runs well on it, what does it matter
Old 01-01-2013, 12:30 PM
The Eddie's Avatar
The Eddie
The Eddie is offline
65-Cetane?
I try to burn B100, from Houston BioDiesel whenever I can, and have since Y2K or thereabouts; I'll never forget just how much the 12V BTA 5.9 smoothed out when the petrodiesel segued to the Bdiesel at the combustion chambers; night and day difference!
I asked HBD's owner (and pump jockey/cashier/warehouseman/buyer/salesman/class instructor/etc., you get the picture) about this phenomenon, and FWIW, he told me Bdiesel has not only higher lubricity values, but B100 has a cetane rating around 65+-, whereas USA-spec petroleum diesel runs 54 (the lowest in the world, BTW). Perhaps exaggerated slightly (c'mon--11 points?), but considering the improvement in engine performance I saw, I have no real reason to doubt him.
Eddie, The
Last edited by The Eddie; 01-01-2013 at 12:39 PM. Reason: Used "'s" when I should'ha used "s'"
Old 01-02-2013, 08:06 AM
MNBen's Avatar
MNBen
MNBen is offline
Diesel is a distillate and is measured in cetane. WMO is a residual and cannot be measured in cetane levels, but should be measured CCAI or CII, in IMO. In reading, the calculation will normally give a value somewhere between 800 and 880. The lower the value is the better the ignition quality. Fuels with a CCAI higher than 880 are often problematic or even unusable in a diesel engine. CCAI are often calculated under testing of marine fuel.
So I think the question people should be asking is what is the CCAI of WMO?
So, does anyone have a number?
Note, all info above was from Wiki searching cetane.
Ben
Old 02-12-2013, 04:57 AM
46/71 Hybrid's Avatar
46/71 Hybrid
46/71 Hybrid is offline
Eddie, The
On my usually traveled route which includes NY, PA, OH, NC, WV, and VA, I have seen several diesel pumps with stickers indicating their diesel cetane rating is 40-45. I think the minimum must be 40 since I've never seen it lower than that. I would love it if the min spec was 54, the highest I've seen is 50 on a few premium diesel pumps.
As far as us being the lowest in the world, I lived in eastern Africa for 2 years and can undoubtedly tell you that their diesel isn't nearly as good as ours. I don't have any hard numbers but I know of several fuel stations that in no way, shape, or form, had a higher cetane rating than what we have in the US.
Old 02-26-2013, 09:09 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
One thing to remember about cetane is every engine requires a different amount, and every engine has a sweet spot. It is possible to put in to much cetane and get a net loss of power. The cetane flashes off to soon in the injection cycle resulting in less power due to the advanced timing.
Diesel Rod
Old 03-31-2013, 11:09 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
5 gallon's 0-20 moter oil, and 5 gallons diesel, 1/2 gallon rug, no differance in how she runs or starts, my oil is virgin,,I get it from work, some atf in the mix as well,, i try to get the light 0-20 oils...
rideracelivemx7
01-03-2011 11:37 PM
Petah
03-16-2009 05:58 PM
sailson
General Diesel Discussion
04-20-2008 10:32 AM
Austin Charles
10-04-2004 08:26 PM
inliner
Oil & Lubrication
29
06-09-2003 05:56 PM
Quick Reply: cectane level: diesel v.s. oil
