Crown Vic IFS Complete.
Old 11-06-2012, 07:17 PM
fordtruck60's Avatar
fordtruck60
fordtruck60 is offline
Man, I thought that these would not be hard to find. Around here in Michigan, I have had no luck finding a complete unit. All the yards or craigslist, ebay, etc, just part them out. Thats alot of $ in parts. Of course thats how they operate and make their money. Any leads on one of these in my area?? Thanks
Old 11-06-2012, 09:55 PM
jo maoma's Avatar
jo maoma
jo maoma is offline
i was running into the same problem they get torn down as soon as
they come in. i ended up making offers in advance for the complete
unit and had two yards call me up less than a week later on the same
day telling me they had them ready. it's easier for them to drop it
as a unit so they were happy to do it. might give that a try....
Old 11-07-2012, 06:24 AM
THartman's Avatar
THartman
THartman is offline
I found mine on Craigslist doing a search for P71 - the CV police interceptor.
Old 11-07-2012, 06:07 PM
fordtruck60
Thanks. The search continues. I have 1 yard keeping an eye out for one.
Old 11-07-2012, 08:54 PM
thrifty's Avatar
thrifty
thrifty is offline
I travel for my job so I am looking for parts. I got a 03 and an 07 in different towns but the same state. I was told the cop cars are in demand and they are the first picked. I got lucky and got both cop versions. You might try Car-Part.com Some of the junkyards list what they have and might make your search easy. Good luck.
Jonesy
Old 11-08-2012, 07:13 PM
fordtruck60
Wow! The yard that had my number actually called today and has one out of a 05 with 36K. They will have it ready early next week with all the bells and whistles including all of the frame bolts!!!!!!!! I guess I couldn't complain when he told me $300.00!! He did know what I needed it for, and is a car (truck) nut too.
So what should I use for the master etc? Also the steering column? I don't need to stay original. Thanks Again Kevin
Old 11-08-2012, 07:25 PM
jo maoma's Avatar
jo maoma
jo maoma is offline
great deal, congrats....
Old 11-08-2012, 08:08 PM
economan's Avatar
economan
economan is offline
seen on the news last week pics of the flooding in NJ a whole parking lot fulla taxis under water, most of em' looked to be vickies. most likely won't be repared from water damage that severe. i'm thinkin' that there is gonna be a mess of vickies (with the HD taxi pkg suspension in wrecking yards soon in that neck of the woods once the taxi companies get paid out by their insurances.
worth keepin' an eye out for anyone down that way.
mikie
near ottawa canada
58 merc 100 panel, 64 econo p/u
Old 12-25-2012, 08:37 PM
fast58's Avatar
fast58
fast58 is offline
I think you were asking about which master cylinder and booster to use. I used a booster out of a 2000 of so Lincoln Town Car because it has a small overall diameter. Any booster will work.
As far as master cylinders go, you just need something out of a Ford that has disc brakes up front and drums in rear. You will also need the proportioning block. This is right under the master cylinder bolted on the same bolts as the master cylinder. My master cylinder and proportioning block came out of a '98 or so F-150 because it is comparable in weight to our trucks with the same "eventual" brake setup. (The proportioning block is so that the disc brakes up front receive more hydraulic power than the drum brakes in rear.)
Check this out. Here are some pictures of when I did this swap.
https://www.ford-trucks.com/forums/1...58-f100-2.html
You may find some helpful hints in there.
PS when you go to buy new brake hoses from the parts store, buy brake hoses for a '98 F-150. The fitting types are the standard fittings. If you buy CV brake hoses you will have to also buy adapters to convert standard fittings to inverted fittings. Which creates a possible leak point. When you install the brake hoses to the frame of your truck, you can simply straighten out the bracket on the hose and bolt it to the frame.
Old 12-26-2012, 08:21 AM
jacks61ford's Avatar
jacks61ford
jacks61ford is offline
or just invert flare the lines as I did
Old 12-26-2012, 04:17 PM
fordtruck60
Thanks guys. Right now everything is on hold until the cash flow gods smile on me again.
Old 12-26-2012, 08:32 PM
economan's Avatar
economan
economan is offline
Nuther' booster/master combo that worked real well for me was a 88 dodge f/s p/u
it fit soooo well i only had to elongate the holes a bit to use the factory holes in the firewall. Also seem to remember using the original f-100 pushrod without mods. Only caveat here is that the booster is too big to use iffin' you still have clutch master cyl.
I did the changeover in about 2& 1/2 hrs.
Mikie
near ottawa canada
58 merc 100 panel & 64 econoline p/u
dusterbd13
07-30-2014 04:43 PM
wmsasser68f100
10-07-2007 06:34 PM
BIG PAT
02-01-2005 12:19 PM
SD Navi
08-16-2004 02:09 PM
Quick Reply: Crown Vic IFS Complete.
