Clutch release bearing question
59 1959 Ford F Series Release Bearing - Clutch - National, PartsMaster - PartsGeek
OK so I decided to do a complete clutch job before installing my engine and trans. The question concerns the parts in the link. What I removed looks like the top part and what I got with my kit looks like the 2nd part. My engine man seems to think I just need to use the new bearing (2nd part) on the old hub without the rest of the assembly. I'm not the kind of guy who wants to install a freshly overhauled engine with a new clutch and a resealed trans only to pull it back apart. Any ideas?
Thanks. I was able to get the old bearing off the hub without much effort using a drift and a hammer. Is that too loose?
Thanks for the info. I did notice the bearing is made in such a way that it slips easily onto the hub when you install it backward and requires gentle pressure to push it on correctly. The designer must have done this so people with common sense would not install it backward
