1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Looking for Carb Replace/ Rebuild Kit
Old 10-30-2012, 02:59 PM
ThreeColt's Avatar
ThreeColt
ThreeColt is offline
I picked up a 1961 F-250 late July and drove her 2,000 miles home over the Rockies and across the plains in 95 F heat. All went reasonably well given any number of getting to know you surprises. I was doing 10 - 15 mpg at about 60 mph. Idle could get rough and fall out after hours of hot running. Couple mornings it was hard to start after a day's work. So I am suspecting a leaky manifold gasket and the carb could use replace/ rebuild. This is the 223 cu 6 cyl with a 1bc carburetor. The only markings I can find on the carburetor are: 12 R 1958.
So can anyone help with the following questions:
  1. What is the carburetor on the F-250?
  2. What replacement carburetors can installed (and where can I find those)?
  3. Where can I get a rebuild kit for the existing carburetor?
Thanks so much for the help. I think it will make a difference.
Old 11-05-2012, 06:35 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is the 223 cu 6 cyl with a 1bc carburetor. The only markings I can find on the carburetor are: 12 R 1958. So can anyone help with the following questions:
  2. Where can I get a rebuild kit for the existing carburetor?
Welcome to FTE
1958/61 F100/600 223 I-6 used the same Holley 1V carburetor & carburetor kits.
C2AZ-9A586-B .. Carburetor Tune Up Kit / Obsolete
GREEN SALES CO. in Cincinnati OH has 44 = 800-543-4959.
C1AZ-9590-A .. Carburetor Master Overhaul Kit / Obsolete
GREEN SALES CO. has 5.
Old 11-05-2012, 10:06 AM
ThreeColt's Avatar
ThreeColt
Thank you Bill. I cannot ask for a better answer than that. I told after the post that 12 R 1958 is only a casting number. In my wanderings I have also run into The Carburetor Shop.
Old 11-21-2012, 12:12 AM
Ianmattf100's Avatar
Ianmattf100
Ianmattf100 is offline
I am looking for a rebuild kit too for a single barrel on my 1963 f100 shortbed. Its the original carb for sure but I dont know what kind. Hres a pic..
Old 11-24-2012, 06:22 AM
ThreeColt's Avatar
ThreeColt
Hey Matt, Tough to tell from the picture. That air filter is definitely not stock. Call The Carburetor Shop ((573) 392-7378). I did not try Green Sales (800 543 4959) per Number Dummy but no doubt they will get you the rebuild too. FYI, The Carburetor Shop did not have a replace, just the rebuild kit.
Old 02-20-2013, 07:18 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
should be a model 1904 holley
Old 02-20-2013, 07:25 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
the 1904 is for the 1961, the 1963 could be a ford f-1 model 1100 ,holley models 1940 or 1909
Old 03-26-2013, 12:45 AM
McMERC's Avatar
McMERC
McMERC is offline
i like the 223, my 63 merc longbed has one and after i got it home and tuned up i had to flush the fuel tank and replace the steel supply lines to the carb. i went to my local parts store and they hooked me up with a reman carb. i keep abot 80 to 85 kph(50-55mph) and get 23 to24 mpg. these little sixers have a nice sound and rythym at that speed (should check with a tach one day ).
the carb i put on was an autoline reman, i'll have to find the bill to get a part number, but these things are available and reasonably priced
jvmcc
08-27-2016 08:00 AM
MadFrank81
04-18-2010 09:19 PM
kadrocker
04-27-2009 03:41 PM
kooper909
06-10-2004 02:42 AM
Quick Reply: Looking for Carb Replace/ Rebuild Kit
