Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Explorer Advance Trac Problem Help!
Old 10-28-2012, 09:31 PM
EchoEv1's Avatar
EchoEv1
EchoEv1 is offline
My battery died and now my AdvanceTrac turns off when I start my 2005 Explorer. I'm concerned with going to the dealer to reset. I don't want them to charge me out the you know what. Does anyone know how to reset the advance trac or how much Ford Dealerships charge to reset if resetting is all that's needed. Help!
<!-- / message -->
Old 10-29-2012, 06:37 AM
shorod's Avatar
shorod
shorod is offline
A well-equipped independent shop may be able to at least pull the diagnostic codes for the AdvanceTrac system and may even be able to attempt the recalibration if that is what is needed. An independent shop will likely be less expensive than the dealer, at least for the scan and code reset.
My Autel DS708 has the capability to initialize and calibrate the AdvanceTrac module and I've tried it out on my 2004 Aviator. If you find a shop in your area with the DS you can be reasonably confident they'll be able to figure out what is causing the light.
-Rod
Old 10-29-2012, 06:18 PM
EchoEv1's Avatar
EchoEv1
EchoEv1 is offline
Thank's, I'll call around to see if a local mechanic has dealt with this before. Until then I am in the dark on this one.
CobraBern
12-18-2010 11:33 AM
melissa_45154
12-14-2008 04:00 PM
teacherdude
02-27-2004 09:22 AM
adc454
08-17-2002 09:22 AM
1977 ranger xlt
08-14-2001 07:38 PM
Quick Reply: Explorer Advance Trac Problem Help!
