1959 ford 302 motor mounts
Old 10-24-2012, 07:56 PM
rodriguezfords's Avatar
rodriguezfords
rodriguezfords is offline
i bought a 59 f 100 with a 302 from a torino in it and c6. the motor mounts it currently has a bolt going across the mount. i am replacing that engine with a 1978 f100 302 that is rebuilt for know until i rebuilt the 71 block. but the motor mounts for 78 have a bolt going down into the frame mount.
my question can a use a 71 motor mount on a 78 302 block?
thanks for the help.
Old 10-25-2012, 03:55 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Same engine supports aka towers, stands, perches.
1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD.
Passenger Car engine supports are not the same as F100/350 supports, regardless of what the engine size is, or what the year is.
Old 10-25-2012, 05:27 AM
rodriguezfords
the towers on the truck were fabricated to accept the motor mounts with
the bolt going across it like this
could i use this on the 1978 302
Old 10-25-2012, 07:49 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
You should be able to. I think the small blocks all have the same spacing on the bosses cast into the blocks.
Old 10-26-2012, 04:59 PM
rodriguezfords
thanks for the help i got the motor mounts for a torino and will insatll the engine tomorrow
estrozyk
20
01-12-2023 03:50 PM
Kai
12-12-2018 03:34 PM
GreatNorthWoods
16
09-17-2009 02:51 PM
bronkntrukholik
04-29-2009 08:45 AM
pacemaker9k
01-31-2003 01:46 PM
Quick Reply: 1959 ford 302 motor mounts
