6.0l ficm
Old 10-31-2012, 05:54 PM
amill's Avatar
amill
amill is offline
Originally Posted by bismic
<TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=18 width=340>04 (post 9/23/03), 05, and up ICP</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=192>4C3Z-9F838-A (ICP on your passenger valve cover)</TD></TR></TBODY></TABLE><TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 26.4pt" height=35><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 26.4pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=35 width=340>03 ICP - 04 (pre 9/23/03)</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=192>3C3Z-9F838-EA</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=340>EBP / ICP pigtail</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=192>5C3Z-12224-A</TD></TR></TBODY></TABLE>
awesome, thanks Mark.
  #92
Old 10-31-2012, 05:57 PM
amill's Avatar
amill
amill is offline
[quote=ramsay;12427838]These are the numbers I've got. Not sure if they are correct but worth a shot.
..............................................FORD ........... INTERNATIONAL.......ALLIANT
03 ICP - 04 (pre 9/23/03)... 3C3Z-9F838-EA ....1845274C92.........AP63407
04 (post 9/23/03) 05 up ICP 4C3Z-9F838-AA .. 1845428C92.........AP63460
.................................................. ..................1845427C2
ICP pigtail ......................... 5C3Z-12224-A .... 1850712C91........AP0021[/quo
thanks for the info.
  #93
Old 10-31-2012, 06:10 PM
amill's Avatar
amill
amill is offline
Originally Posted by BLADE35
You Did NOT have to pull the Turbo
But Since you did its WAY Easy now just use a Cresent wrench to get it out
If Pigtail wire insulatiopn is Bubbling and bad replace pigtail
If just has oil on it clean pigtail with Carb Cleaner good and should be OK
i've been wanting to clean the turbo thats why i took it off. the intake manifold crossover tube is in the way so i'm gonna loosen the exhaust Y-pipe to get at it. i'm gonna mill out the inside of an 1 1/16 socket to make a sensor removal tool.
i'm gonna replace the pigtail cause it's a cheap Delphi part. Delphi is GM parts right? i don't want GM parts on my truck.
thanks for all your help Benny, i owe you big time.
  #94
Old 10-31-2012, 06:12 PM
amill's Avatar
amill
amill is offline
gotta take the kids trick or treating now, ill get back on later. thanks again everybody.
  #95
Old 10-31-2012, 09:56 PM
amill's Avatar
amill
amill is offline
Thumbs up
Looks like you saved a couple hundred Bucks
By not sending a Good FICM for repair
was a good thing you asked I see alot of folks come here and post there problem after they already have thrown a Bunch of parts at it with no luck to correct the problem
once again this site saved my ***!
  #96
Old 11-06-2012, 09:59 PM
amill's Avatar
amill
amill is offline
finally able to order parts! YAY! hopefully be back on the road next week. i'll keep you posted.
thanks everybody
  #97
Old 11-17-2012, 09:00 PM
amill's Avatar
amill
amill is offline
hey everyboby it just keeps getting better[worse]! does anybody have the part number for the ipr pigtail and the harness that connects the ficm to the injectors? the icp and ipr are both under the turbo if that helps. i've been searching and found some part numbers but can't figure out which one i need. also has anyone used the lisle 68210 ipr socket? as usual thanks for all the help
  #98
Old 11-17-2012, 09:24 PM
bismic's Avatar
bismic
bismic is online now
Received 2,483 Likes on 1,722 Posts
<TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 25.2pt; mso-height-source: userset" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 255pt; HEIGHT: 25.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=34 width=340>IPR pigtail (to use to command the IPR valve closed)
for air testing the HPO system
</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=192>6E7Z-12A690-DA</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 73.35pt; mso-height-source: userset" height=98><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 73.35pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=98 width=340>03 FICM Harness (and early 04)</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=192>3C3Z-9D930-AA</TD></TR></TBODY></TABLE>
  #99
Old 11-17-2012, 09:36 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
On no what happened???
  #100
Old 11-17-2012, 09:59 PM
amill's Avatar
amill
amill is offline
the ipr pigtail is missing chunks of insulation and the wires are shorted together. the injector harness is oil soaked and some of the insulation peels right off with my fingernail. and i need to order an ipr socket, i was lookin at the lisle 68210 on amazon for $17.34, i think it'll fit up in there. no big deal just more to do, and more money to spend.
  #101
Old 11-17-2012, 10:01 PM
amill's Avatar
amill
amill is offline
[quote=bismic;12496953]<TABLE style="WIDTH: 411pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=548 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 144pt; mso-width-source: userset; mso-width-alt: 6826" width=192><TBODY><TR style="HEIGHT: 25.2pt; mso-height-source: userset" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 255pt; HEIGHT: 25.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=34 width=340>
</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 144pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=192></TD></TR></TBODY></TABLE>
do you know if this is the updated harness with the plastic redirects on the ficm connectors?
  #102
Old 11-17-2012, 10:07 PM
amill's Avatar
amill
amill is offline
$55 for the icp pigtail, but only $7.70 for the ipr pigtail! thats alright though i already have the icp pigtail from my first order from Tousely. $155 for the injector harness, pleasantly surprised. thanks guys.
  #103
Old 11-26-2012, 07:26 PM
amill's Avatar
amill
amill is offline
can anybody tell me what a normal reading for icp should look like on a sg2? i keep getting letters and numbers with no consisitency. maybe i programmed that x guage wrong, i don't know.
  #104
Old 11-26-2012, 07:54 PM
BLADE35's Avatar
BLADE35
yes its wrong
numbers only for a Reading ICP@ 620 or 580 Depending on stratigy or year
Do these all 3 of these
ICP 07E0221446 046205140646 3010 003900640000 Injector Control Pressure (PSI)
Key On = 0
Low Idle = 625.5
High Idle = 1400
1450
Operating Range = 0
4045
ICV 07E02216AD 0462451606AD 3010 004827100000 Injector Control Voltage (Volts)
Key On = 0.2
Low Idle = 1.0
High Idle = 1.8
Operating Range = .15
4.7
IPR% 07E0221434 046285140634 3008 0DCA03E8000A IPR Duty Cycle (%)
Key On = 14.84
Low Idle = 24
High Idle = 40.60
Operating Range = 0
50
  #105
Old 11-26-2012, 08:16 PM
amill's Avatar
amill
amill is offline
yes its wrong
Key On = 0
Low Idle = 625.5
High Idle = 1400
1450
Operating Range = 0
4045
Key On = 0.2
Low Idle = 1.0
High Idle = 1.8
4.7
Key On = 14.84
Low Idle = 24
High Idle = 40.60
Operating Range = 0
50
ill go check it out now. where did you get the icv codes from? there not on the sg website.
Quick Reply: 6.0l ficm
