Parking brake Drum for '57 F800
Old 10-17-2012, 11:05 AM
acfd's Avatar
acfd
acfd is offline
I've discovered a crack in the parking brake drum on our 1957 F800 fire truck. I check my parts catalog and I believe that the correct part number for this would be TGAA 2614-A. Can anyone confirm this and does anyone have any idea where I might find one (new or used)?
Old 10-17-2012, 09:45 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
acfd; if you can (not sure if you have enough posts?) PM FTE member "NumberDummy", Bill may be able to find this for you or tell you if the part has a newer number.
Old 10-21-2012, 03:51 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
TGAA-2614-A is correct, but no Ford Dealer or obsolete parts vendor has any.
OP is aware as he contacted me.
Old 10-22-2012, 06:56 AM
acfd's Avatar
acfd
acfd is offline
The truck has a Clark transmission in it. Would this have been a part which was made by Clark and could possible have a different part number, or was this a part made by Ford?
Old 10-22-2012, 07:19 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
I've seen one on eBay for like a year. Maybe its the one u need
Old 10-22-2012, 06:27 PM
spurredon's Avatar
spurredon
spurredon is offline
This may be not correct but could this original be welded? Looks like you could build it up on the inside surface and then grind the outside back smooth after welding. Never done it but have seen sicker calves than that get well!
Old 01-24-2023, 09:43 PM
Big Kaz72's Avatar
Big Kaz72
Big Kaz72 is offline
Parking brake alternative?
I have a 57 800 Big Job. The previous owner has for some reason removed the parking brake system minus the handle. Does anyone have an idea on where I can find a replacement assembly or some sort of alternative? Thanks!!!
willowbilly3
04-10-2017 04:43 AM
f150lariat
11-08-2016 09:01 AM
Piolet
02-19-2012 07:41 AM
moonley
09-21-2011 09:09 AM
Quick Reply: Parking brake Drum for '57 F800
