4bbl manifold for a 390
All is well with the engine, from the looks of it something just caused the timing to jump so now I dont have to worry about an engine swap anymore. I can get a Holley 4bbl but now my only thing is finding a manifold for the engine. Anybody have a 4bbl intake looking to get rid of, its a 390FE.
since the timing gears got, due to bad gas/water in the fuel, were gonna get a new set of them as well as another lifter as one of the went to bits. I've got a full set of push rods so basically after we replace the timing gears it's back together it goes and since we done took off the intake I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***.
I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***. that's funny...... but seriously there might be something more serious if a 2bbl 390 doesn't have that much power (i have run 360's and 390's w/ 2bbl and they were plenty stout) and you said it jumped time i had a 352 jump time and all sorts of bad things happened how did your dizzy gear look when you pulled it out???
We havent pulled the gears out yet, thats our goal for today. Hopefully nothing else will go wrong as from the looks the heads are in good shape and from what we looked at the cam everything seemed to be in good condition. Anything that came off the truck my dad would have looked at and would have been able to tell right off as he has a little experience with old dentsides as one he used to have was a 77 f100 with a 302.
Another question, in all of yall's opinion, would I be better off with a holley 650 or quadrajet 600? I got a holley but a guy I know wants it to drop it on his blazers's 350 he just dropped in it. Main reason I'm asking because he seems pretty insistent and he says the quad was setup for a ford but I thought the quadrajet was about the best you could get period for a carburator, just curious on that one.
mvcp
15
01-13-2019 08:18 PM
dusty2052000
03-20-2006 09:23 PM
custom69
17
05-10-2005 11:43 PM
OneFine69
18
12-23-2002 11:30 PM
