heater blows cold air
Old 10-08-2012, 07:20 PM
JP Hobbit's Avatar
JP Hobbit
JP Hobbit is offline
Folks got a question and request for help. My 02 F150 V6 only blows cool air when set for heat. Did a bit of internet searching and factors involved. Radiator fluid is full. truck does not run hot (temp gauge shows normal), heater hoses=one gets hot the other feels cold when heater is "supposed" to be running. So I'm thinking it's either heater core is clogged or maybe heater control valve or blend door issue?? Any and all thoughts/advise would be appreciated.
Old 10-08-2012, 08:18 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Either the heater loop is clogged, the thermostat is bad, or the pump is weak.
Old 10-08-2012, 08:28 PM
JP Hobbit's Avatar
JP Hobbit
Should have stated this as well. Had water pump replaced earlier this year so I doubt the water pump is part of the problem.
Old 10-09-2012, 06:14 PM
godsmkNH's Avatar
godsmkNH
godsmkNH is offline
did you have heat after the pump was changed out maybe or hopefully a air block ? just a thought
Old 10-09-2012, 08:38 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
If gauge is normal, then i would assume the thermostat is working also. I dont like the heater hoses, one hot, one cold idea. Im not sure there is a water valve on that truck. My 2001 5.4 has no valve. I think i would take both hoses off (heater) and connect garden hose to one end and flush thru good to see that if flows good... Also, turn the fan on very low speed, and the heater hose outlet should be about as hot as the inlet. Either no flow from heater pluggage, or some type of water valve.
Old 10-10-2012, 07:27 AM
projectSHO89
I learned a long time ago (the hard way, of course) that just because something is new(er), it cannot be assumed to be good.
Propr801
1997 - 2003 F150
01-19-2009 07:06 PM
rustee90-150
12-14-2008 08:37 AM
jtimcort
18
11-27-2007 03:45 PM
Bunka
11-29-2004 03:22 PM
Morris Holota
07-22-1999 10:47 AM
Quick Reply: heater blows cold air
