how much can i tow
Old 10-09-2012, 11:46 AM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
i am from Kansas so we don't have too many hills but we do have some that are pretty decent but probably not compared to your PA or MO
Old 10-09-2012, 02:01 PM
Spktyr's Avatar
Spktyr
Spktyr is offline
Just because your truck can get a weight moving doesn't mean it can stop that weight - legal max towing and payload ratings take that into account. Our trucks brakes were decent enough for the day but by modern standards they're not very good; that's why our ratings are (relatively) low and new trucks have much higher ratings.
To use a graphic example, the 15" wheels most of our trucks came with from the factory won't even fit over the rotor and caliper of a new 150. The 16" wheels might just barely fit, might not.
Old 10-09-2012, 09:43 PM
Daniel5.0's Avatar
Daniel5.0
Daniel5.0 is offline
Originally Posted by Conanski
In my '90 owners manual the GCWR(combined weight of truck, trailer, and all cargo and passengers in both) for a 5.0/5-speed is 6450lbs with 3.08 gears, 7800lbs with 3.55 gears, and 10000lbs with 4.10s.
What you're looking at is a 3000 (for sure) pound tractor, 1500(?) trailer, and 5000(?) truck. Sorry, I've never weighed the whole rig. I'm not going to win any races, but the truck handles it with ease. And before you start in on me, the trailer has working brakes and we put proper tongue weight on, etc etc. It's not an unsafe load. I have hauled tractors up to 4500 pounds with no issues.
Old 10-09-2012, 09:47 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I am guessing your truck weighs closer to 6000 and the trailer at about 2500lbs
Old 10-09-2012, 09:54 PM
Daniel5.0's Avatar
Daniel5.0
You may be spot on, honestly, I don't know.
Old 10-09-2012, 09:55 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I doubt that truck is anywhere near 6000 pounds. My friend's '96 F-250 460 CCSB 4x4, with 31" tires, tool box filled with tools, subs, and him in it weighed 6560 pounds.
Those OBS F-150s could get very light. I believe RCSB 2wd models with the lightest engine (302?) could squeak in at around 4000 pounds.
Old 10-09-2012, 10:09 PM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Closer to 5000lbs. My 96' SCSB 4x4 5.8 auto comes in at 5240lbs with a 1/4 tank fuel in each and nothing (not even me) in it.
The legal load versus what load you're comfortable towing are usually very different, but in an accident only one matters.
Old 10-09-2012, 11:10 PM
dakota1820's Avatar
dakota1820
dakota1820 is offline
hey guys my door tag does say 8650gvwr . ford told me today though that the gcwr is 6450.... i am confused. i could upload a picture of the door tag but i promise it says 8650 gvwr. the truck does have five leaf springs the heavy duty cooling system rear sway bar ect.... but i am confused i just want to know what it can tow and what is the payload.
Old 10-09-2012, 11:33 PM
91chevywt's Avatar
91chevywt
91chevywt is offline
GCWR=Gross Combined Weight Rating=Max weight of truck + trailer loaded
GVWR=Gross Vehicle Weight Rating=Max. weight of truck loaded
Something is mixed up here. 8650 GVWR is F250HD/F350. Check your VIN with this link GVW=GVWR
Truck Parts and Truck Accessories
Old 10-09-2012, 11:55 PM
Shwan_89HD's Avatar
Shwan_89HD
Shwan_89HD is offline
Originally Posted by smokenchoken
i don't know the weight of the load but i know my 92 with a 302 and AOD-E 3.73 gears didn't have a problem pulling a 4 horse trailer and 3 full size overly healthy 16 hand tall bay's doing 65 right down the highway she wasn't straining hard at all i still refused to use overdrive in that situation though..... but since you have a manual it should do better and give you more options too
Dang!, 3 horses thats 3k pounds, and the trailer itself must be 3 or 3500 pounds. Plus goin 65mph thats alot of work for a 302. im impressed and thats cause i drive a 3/4 ton 351w
Old 10-10-2012, 12:20 AM
smokenchoken
i have never understood why people dog the 302 i have always loved them they are a good blend of power and efficiency and they have a great aftermarket too
Old 10-10-2012, 06:46 AM
Daniel5.0's Avatar
Daniel5.0
Another point I was going to make about mine: there's plenty of power available if you get your RPMs up. Problem is, you can just about watch your gas gauge drop. Keep it around 2000-2500 and things are much better, but plan on downshifting on most hills.
  #28
Old 10-10-2012, 10:08 AM
Diesel_Brad
Thats odd. My CCLB 460 5spd truck weighs 7200lbs
And my reg cab short bed lightning weighs 4400lbs
Both with out me in them
  #29
Old 10-10-2012, 10:59 AM
Lead Head's Avatar
Lead Head
I can't imagine an extra two feet of bed and frame adding 700 pounds. I'd suspect the scale you used was a little off, or you had both tanks full of fuel.
My buddy used the scale on his base, so I assume it's kept reasonably well calibrated.
  #30
Old 10-10-2012, 11:32 AM
Diesel_Brad
Local scrap yard. Weights and measures is there every month to check accuracy. I cant remember full of fuel or not But 2 fuel tanks only weighs 250lbs. I know the lightning was published as 4400lbs so I know that is right on
Quick Reply: how much can i tow
