weight distribution hitch reese dual cam vs equalizer
hey guys just looking for a little input I am purchasing a new wolfpack toyhauler travel trailer 35' and can't decide on which wd hitch to get. I have heard both the dual cam reese and equalizer are good but which one is better for towing with the excursion any thoughts or experience? Also I have a 5" suspension lift and 35" tires can't decide on which drop shank I need equalizer makes a 6" max drop and also a 9" max drop should I go with the 9" just to be safe?
They both will work well, but I will give a warning about the Reese. Some of their stuff is not coming through with good quality control. All the Reese stuff is now made in China. I ended up scrapping my one year old Reese Dual cam due to quality issues and tried something else. Some folks are getting good sets, some are not. To see the specific things to watch for, read and look at the diagrams on the folowing link:
RV.Net Open Roads Forum: Towing: Not happy with my Reese Dual Cam
Ya I was leaning more towards the equalizer anyways because I haven't heard a bad review yet on its performance. The only negative reviews have been on it being a little noisy. I just want to make sure I get the best one especially with having a suspension lift because I live in Colorado and make two or more trips to Florida a year and just want to be on the safe side. What do you think on the drop shank?
Shank Sizes
They make it easy to pick the shank. Do a couple measurements and plug it in the formula on their website.
I have an Equalizer. Easy to set up, easy to hook up and seems to do it's job well. Only complaint is it's noisy at times. Can be made pretty quiet with fresh grease in the right places.
I have a Reese dual cam sway set up. I didn't realize that there were so many complaints. When I got home I double checked all my hardware. After 2 years and over 20 trips at about 150-200 miles per trip, it all looks great. I like the way it pulls and distributes the weight. No complaints from me. The bars and cams have min. wear and look like they are wearing evenenly. Reese has my vote
First you are talking about two separate issues here. The Reese Dual cam is sway control not weight distribution. The Equalizer dores have a product which does both sway and WD. I tow a 32' Airstream and have used both with satisfactory results. Presently I am using an Airsafe hitch with the Equalizer for WD and sway. This combination has given me the best ride, and safety while towing. The draw back is the greasy bars, and actual weight of the Airsafe and Equalizer. There are newer products on the market which utilize just chains to achieve the WD. I will most likely switch to one of these to avoid the weight and grease.
The chain system is called Anderson No Sway WD Hitch, Andersen No Sway Weight Distributing Hitch field test by www.MrTruck.com - YouTube
I think you're mistaken. The Reese is a weight distubeter please see this link.
Strait-Line Weight Distribution with Sway Control - Trunnion Bar - 10,000 lbs GTW, 800 lbs TW Reese Weight Distribution RP66073
Thanks for all the info guys I have decided to go with the equalizer with the 9" max drop shank. One more question though I was going to go with the 1,200/12,000 hitch but the dealership thinks I should go with the 1,400/14,000 hitch just in case I decide to upgrade my tow vehicle and trailer later on will that be overkill?
Uh-huh.. Snake oil.
It seems to pull my 34 foot 9000lb travel trailer with a 1250lb tongue weight pretty well.
Sure wish I had talked to you before I bought one. I sure could have saved myself from being happy with it.
