ECU Location 1991 E 250
Old 10-02-2012, 06:17 PM
Falcon39's Avatar
Falcon39
Falcon39 is offline
The title says it all. I've been all over the web looking for where this is.
Several references ended up being the ABS computer. I pulled it and drove all over town so I know that's not it.
Old 10-02-2012, 08:50 PM
kb1jid's Avatar
kb1jid
kb1jid is offline
ECU location
Its inside the van, pass side, under the heater box. Its covered with a plastic cover And under the hood there is a 10mm bolt that you have to undo before you remove the ECU from inside the van
Old 10-02-2012, 10:19 PM
Falcon39's Avatar
Falcon39
Falcon39 is offline
Thank for the assist
kb1jid,
Thanks. It's 11:20 raining and dark now but you can bet I'm all over this in the morning.
I'll let you know how it turns out.
Falcon39
Old 10-03-2012, 01:10 PM
Falcon39's Avatar
Falcon39
Falcon39 is offline
kb1jid,
OK, thanks, I found it. Now how do I get to the mounting bolt behind or below the A/C blower in the engine compartment?
Old 10-03-2012, 01:52 PM
kb1jid's Avatar
kb1jid
kb1jid is offline
i took out my battery and reached under the ac box and felt around till i found it there is a big elect conector about 1 by 6" long with the bolt in the center of it
Old 10-03-2012, 02:26 PM
Falcon39's Avatar
Falcon39
Falcon39 is offline
I thought that might be the way. Working blind seems like all I've been doing lately.
I have a 2003 Impala down now too and everything requires an additional elbow on one arm or the other.
May not be able to get to it again until tomorrow but I really appreciate your help.
Old 10-31-2012, 10:40 AM
Falcon39's Avatar
Falcon39
Falcon39 is offline
Kb1jid,
Been a long time since your help. I was called out and got involved elsewere but I came back and was able to swap out the ECM just as you described. Thanks for your help.
Falcon39
Tom Armstrong
04-18-2019 09:31 PM
BrianLaverty
20
11-19-2018 01:34 AM
annaleigh
04-30-2017 03:53 PM
justforkicks
12-04-2011 09:06 PM
pjlandry
06-17-2007 04:50 PM
Quick Reply: ECU Location 1991 E 250
