Interference engine?
Old 09-25-2012, 09:36 AM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
Is my 98' 5.4L 2V an interference engine or not. Also what about the other Ford modular engines from 97'-2010? Which are and which aren't?
Old 09-25-2012, 08:30 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
define interference ?
Old 09-25-2012, 10:42 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
He is asking if the cam drive chains were to fail and leave any valves at max lift, would the pistons hit them?
Old 09-26-2012, 07:07 AM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
That's right.
Hey postmaster, coreyallenal scooped your answer. It that a spamer that I was warned about recently on your site?
Old 09-26-2012, 11:37 PM
Torky2's Avatar
Torky2
Torky2 is offline
Yup, user "coreyallenl" is a spammer, I just reported it. If other users here would report spammers when they see them via the red "!" alert icon to the right of the psammer's posting, they would be removed quicker, as I usually don't get on here till late. List the spammer's username in the resulting report dialog box so there is no confusion and to make it easier on the moderators.
Interference Engine question - From the 1997 shop manual 4.6L engine section, has the following warning:
CAUTION: At no time, when the timing chains are removed and the cylinder heads are installed may the crankshaft or camshaft be rotated. Severe piston and valve damage will occur.
My early edition 1997 manual does not have the 5.4L in it, but I would expect it to be the same.
Old 09-27-2012, 06:00 AM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
Thanks, that's good to know.
fordbeast_80
04-12-2004 11:01 PM
COhunter
02-04-2004 12:33 PM
2rockyou
Performance & General Engine Building
11-29-2002 08:08 AM
hankm
01-17-2002 06:38 AM
Quick Reply: Interference engine?
