1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Original wheel size(s) for 1963 3/4 ton Unibody
Old 09-23-2012, 03:59 PM
skitvader's Avatar
skitvader
skitvader is offline
Trailering
Hi world. I'm new here, and I have searched the forums without luck on this question. Apologies if this has been asked previously. I bought a 1963 3/4 ton (F250) Unibody and I really don't like the aftermarket rims the previous owner put on it. I would love to find factory type steel rims/hubcaps to give it a more vintage look. Right now it has LT235/75/R15s on it and the previous owner tells me that he believes 15" was the stock size (he was the 2nd owner, but he admittedly is the guilty party who swapped them out 5 years ago leaving the original rims at the shop he bought the aftermarkets). I'm not having any luck finding 15" stock rims in 8-lug, is that becuase they're super rare, or they never came in that size Thanks for your insights.
Old 09-23-2012, 05:47 PM
lostinafog's Avatar
lostinafog
lostinafog is offline
16" Innies believe part # B4TZ-1007-A
Old 09-24-2012, 09:36 PM
skitvader's Avatar
skitvader
Trailering
Thanks for your feedback. That's what I was thinking too. Good news, I located a full set of 16" innies with original set of hubcaps, and they're in my garage now. Very excited. I also checked the spare, and can see that it's original (I can see that it's an innie, but will need to drop it out to measure, but that's a set of 5!)
Old 09-25-2012, 04:55 AM
lostinafog's Avatar
lostinafog
Originally Posted by skitvader
Thanks for your feedback. That's what I was thinking too. Good news, I locate a full set of 16" innies with original set of hubcaps, and they're in my garage now. Very excited.
great to hear ! post some pics of your uni
Old 09-25-2012, 07:21 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Welcome to FTE skitvader. Man thats a lucky find Ive been looking for 4 or 5 non split rim innies for almost a year. Are the ones you came up with non split rims. Just wondering because I have found many of those. I dont find them often but way more often than the non split 16 innies. If those are non split I just want to say you lucky dog. Pics are good.
Old 09-25-2012, 09:07 PM
skitvader's Avatar
skitvader
Trailering
Hey there Buzz (Vic), thanks for the vote of confidence; I felt like I might have overspent, but I've been looking for months myself and was willing to step up as I felt they wee pretty rare. I got lucky, but it wasn't without a lot of searching. They are NOT split rims. I got a full set of 4 + the set of hubcaps to boot. Now I need to get tires to go on these things. The truck has 15" now, so the tires will not swap over.
I posted pictures here: Ford Truck Enthusiasts Forums - skitvader's Album: Skitvader Pictures
Feedback welcome, I suspect they may be later (like '65), but that's CLOSE enough for my 1963.
Old 09-27-2012, 01:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
These are 16" F100 wheels, as they have 5 holes on a 5.50" bolt circle pattern.
F250's have 8 holes on a 6.50" bolt circle pattern. 16" F250 innie non split rim wheels: B9TZ-1015-A
Old 09-27-2012, 03:05 PM
skitvader's Avatar
skitvader
Trailering
Thanks for the information Bill. I assume the part number will be stamped on the rim somewhere, and I'll look for it and see what I have. They're 8 lug, and the Ford stamp stood out immediatly (pictured).
Old 09-28-2012, 12:47 AM
NumberDummy
Previous owner tells me that he believes that 15" were the stock size.
Previous owner hasn't a single clue!
I'm not having any luck finding 15" stock rims in 8-lug, is that because they are super rare.
The reason you cannot find these wheels is: They do not exist!
No F250 came from the factory with 15" wheels: N-O-N-E = NONE!
1953/66 F250's came with 8 lug 6.50" bolt circle 16" wheels as standard equipment, as did all 1967/98 F250's.
1953/66 F250's were also available with 8 lug 6.50" 17.5" x 5.25" split rims & 19.5" x 5.25" non split rim wheels as an option.
1967/79 F250 Camper Specials came with 6.75" x 16.5" 16" wheels, required 8.75" x 16.5" tubeless tires. Not EZ to find today.
B9TZ-1015-A = 1959/67 F250 innie non split rim 16" wheel stamped with manufacturer's number: 31031.
Old 09-28-2012, 01:13 AM
skitvader's Avatar
skitvader
Trailering
I took a flashlight out and looked over one of the rims in my garage. Didn't find a part number, but it wasn't the best lighting condition. I'll look further tomorrow.
While I'm here though, anyone have suggestions on tire size to put on these 16" rims (in terms of current measurements)? I would like to have the spedometer as close to accurate as possible. I actually don't mind the look of the LT235/75/R15s it has on it now - fill the wheel wells pretty nice IMHO, but now that I know they're not original my spedo may have been off since I bought the truck 8 months back. I didn't bother to check.
Everyone's feedback is appreciated, you guys are a wealth of knowledge and generous with your advice.
Old 09-28-2012, 01:42 AM
NumberDummy
Your speedo is absolutely inaccurate based on the aftermarket 15" wheels and the P-Metric 15" radials. Neither existed on any F250 as original.
Even with correct 16" wheels, your speedometer will never be 100% accurate as radial tires were not factory installed on these trucks and the P-Metric radials used today are a different shape.
The original tires were bias-ply blackwalls. There's another problem, your 1963 F250's speedometer DRIVEN gear at the end of the cable. It could be fibre, it could be cast iron, or it might be nylon.
DRIVEN gear teeth are based on the type of transmission, rear axle ratio, series of truck, 2WD or 4WD and the original bias-ply tire sizes.
16-21 tooth nylon gears are EZ to find as all are available from Ford. Correct tooth count fibre or cast iron gears may be impossible to find.
Post the AXLE & TRANS codes that are stamped on the Warranty Plate. Once decoded, will know what material the DRIVEN gear is made of, how many teeth it has based on the original 7.00 or 7.50-16 tire sizes.
Old 09-28-2012, 01:13 PM
skitvader's Avatar
skitvader
Trailering
Thanks for your onging help. Below is a picture of door plate on the truck - in case it helps. To answer your questions on the codes:
Axle: 24
Trans: F
Old 09-28-2012, 01:45 PM
skitvader's Avatar
skitvader
Trailering
On the rim part number hunt, I'm not finding any further markings. They've been blasted/painted which may make it more challenging, and I'm not sure where to be looking. Besides the Ford logo on the front, I also found what appears to be a "K-H" stamped on the front (opposite the Ford script). I measured them and they're 16 x 6, they're 8-lug Ford Innies, that much I know
Old 09-29-2012, 01:52 AM
NumberDummy
K-H = Manufactured by Kelsey-Hayes.
Old 09-30-2012, 01:02 PM
skitvader's Avatar
skitvader
Trailering
I've been doing some non-scientific online research, and the prevailing opinion I'm seeing is that the modern day equivalent of the 7.5 x 16 is the 215/85R16, and they are a good match up for 16 x 6 ford rims. Anyone running these or have an opinion one way or the other?
4GOTNF250
06-12-2016 11:51 PM
jaskoskip
01-01-2016 11:08 AM
Front1/4
1947 and Older Ford Trucks
01-21-2013 09:41 AM
brembo
10-10-2010 05:10 PM
cappyd892
12-17-2007 07:15 PM
Quick Reply: Original wheel size(s) for 1963 3/4 ton Unibody
